HandsFreeLink Lock--Don't have passcode
Old Aug 14, 2004 | 06:15 PM
Zoltan74's Avatar
I am trying to setup the HandsFreeLink to work with my new Bluetooth phone. I guess the dealership setup a passcode on the car because it says that it is locked and I need to enter the 4-digit passcode. How do I reset this if I do not know it? Thanks.
Old Aug 14, 2004 | 10:30 PM
Are you referring to the 4-digit PIN used for pairing? This is something you select and then enter into the phone. If the dealership paired your car with another phone you can just create a different pairing. Check out the instructions in the manual or go to Acura's Owner Link:
http://www.ahm-ownerlink.com/Operati...dsfreelink.asp
They have instructions on pairing lots of different model phones.
HTH,
Peter
Old Aug 14, 2004 | 11:16 PM
Zoltan74's Avatar
I don't think it is...
Thanks for your reply. I don't believe so. The first thing the system asks for is a passcode because the system is locked. Today is the first time I tried using the system as I just purchased a bluetooth phone today.
Old Aug 15, 2004 | 12:32 PM
ryder1650's Avatar
Try 1234 maybe or 0000. If these do not work you can try disconnecting the battery for a little while to reset the whole system. You will have to re-enter all of you radio codes again, though. If you are not sure the procedure for this, I'm sure someone here can help you. If you take it to the dealer to be fixed, I'm sure they would do the same thing.
Old Aug 15, 2004 | 02:01 PM
żGotJazz?'s Avatar
Cesspool of Knowledge
It looks like someone (maybe the dealer, as a precaution) has accidently screwed you over on this. There is a HFL security option to password protect certain functions. You will probably need to take it back to the dealer to get the passcode. Pulling the battery might fix it, but I sure would hope not.
Tim Giron
Mar 18, 2016 09:50 PM
TheOne305
Jun 11, 2008 06:42 AM
Dum_guy_n_tl
19
May 13, 2005 11:16 PM
Tommy TL
Feb 17, 2005 12:47 AM
