gps antenna for nav
Old Apr 20, 2008 | 06:59 AM
blue04tl's Avatar
gps antenna for nav
Hello everyone I have a question i'm doing my non-navi to nav install today and I just wanted to know where specifically do you mount the gps antenna in the car?
Old Apr 20, 2008 | 07:12 AM
jayv's Avatar
mine was a aftermarket one that i got from fleabay... it was magnetic.. i put it between the rear speaker and rear window there is a little low spot there that it fit in....
Old Apr 20, 2008 | 07:40 AM
blue04tl's Avatar
so there is a spot in between the speaker and the the window do you have to lift up the carpet to find it i think my gps antenna is aftermarket to its a trimble, but i dont know also do you get a good connection is there any interference since the antenna's not outside the car. The reason why Im asking this is because I want the install just like it came from the factory so when I get ready to trade or sell no one can't tell I did nav conversion.
Old Apr 20, 2008 | 08:12 AM
jayv's Avatar
yeah you have to remove the rear seat, rear c pillars, and rear deck.. its under there... on the passenger side... there is a write up on removing all this stuff in the garage.. its for doing suspension.. but its all the same... search for it and you will see.. thats near the stock location and you wont see it when its all put back together
Old Apr 20, 2008 | 10:46 AM
jptl04's Avatar
Bone stock tl-s
^^^^^^ yes, what jayv said. if you have the oem antenna it's mounted on a metal bracket with two holes. once you remove the rear deck, on the passenger side there's already some holes there that match it up perfectly. two screws/bolts hold it in place. thats where it goes.
Jul 16, 2017 07:33 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
us285126
Oct 2, 2015 02:03 PM
rhdune16
Sep 28, 2015 11:31 AM
