Good speaker replacements
Old Sep 11, 2007 | 02:31 PM
  #41
BAD DNKY's Avatar
Tripnbeats you do this for a living?
Old Sep 11, 2007 | 04:40 PM
  #42
jvinhj240's Avatar
YOur amps doesn't have output?
Old Sep 11, 2007 | 06:52 PM
  #43
BAD DNKY's Avatar
amp does stock radio doesnt
Old Sep 11, 2007 | 10:17 PM
  #44
jvinhj240's Avatar
if you convert 1 from stock to after market, and continue on from your aftermarket output.
Old Sep 11, 2007 | 10:48 PM
  #45
Tripnbeats's Avatar
nope Im a network engineer.... i have a shop though and I do all the installs on the side....been doing it for years....also do upholstery
Old Sep 11, 2007 | 10:50 PM
  #46
Tripnbeats's Avatar
no, the amps have outputs... but separation of channels is really much better in equalization...depending on what u use to balance ur sounds.
Old Sep 12, 2007 | 07:44 AM
  #47
BAD DNKY's Avatar
should the converters be hooked up behing the headunit?
Old Sep 12, 2007 | 07:56 AM
  #48
BAD DNKY's Avatar
ok i also need some help on the gauge of wire i need to use. I got a rockford amp instead of the kenwood. Its birth cert. says 65w at 4ohms x 2 and i am also hooking up a mtx amp to the subs which i believe is 175w x2 (ohms?). I am thinking of branching off the main line to each amp in the rear of the car. 4 gauge enough or too much?
Old Sep 12, 2007 | 08:13 AM
  #49
rodneyc77's Avatar
Retired!!! ON TOP!!!
4 guage would be more than enuff...
The converter (LOC) should be hooked up to the speaker level wires coming OUT of the factory amplifier heading towards the speakers...
PM me with your e-mail if you want a wiring diagram...
Old Sep 12, 2007 | 08:31 AM
  #50
Tripnbeats's Avatar
thanks rod
Old Sep 12, 2007 | 08:41 AM
  #51
Tripnbeats's Avatar
bad your mtx amp is 4 ohms Im about 99% sure =)
Old Sep 12, 2007 | 10:20 AM
  #52
BAD DNKY's Avatar
why is that bad?
Old Sep 12, 2007 | 12:08 PM
  #53
Tripnbeats's Avatar
I was refering to ur name dude lol!
Old Sep 12, 2007 | 12:35 PM
  #54
BAD DNKY's Avatar
haha i swear im not special! It stands for my Licence plate Bad Donkey (ASS)
One more question: I see rating of Amps in 12.5v and 14.5 volts. For out purpose car put out 12v. Is there a way for the amp to receive 14v or does it actually receive 14v when you take into consideration the remote wire?
Old Sep 12, 2007 | 12:50 PM
  #55
Tripnbeats's Avatar
ur car puts out 13.5 all the time.....12 is like the standard way of putting it.... the alternator charges at 13.5 - 14.5 all the time depending on rpm speeds... now with the car off, at time of ignition starts with 11.5...as soon as the first crank is achieved the voltage spikes and regulates at 13.5. the remote cable is always 12volts.
Old Sep 14, 2007 | 09:56 PM
  #56
BAD DNKY's Avatar
ok so i am getting my amp for my subs tomorrow ( old amp i let a friend use) I believe its 325w at 4 ohms. Now i have two subs. One JL 12 inch 12w08 (125w 8 ohm sub) in a regular sealed box and then i have a single 10 inch mtx blue thunder extreme (500w rms at 4 ohms) in a truck box. What sub should i use with the amp i have? I think the 10 inch is the way to go but believe a bigger box would make it sound better. This true?
Old Sep 15, 2007 | 12:47 AM
  #57
Tripnbeats's Avatar
bigger box if ur going ported/vented....sealed smaller.....also depends on the excursion u want from the sub
Old Sep 15, 2007 | 08:13 AM
  #58
BAD DNKY's Avatar
i dont remember the sub hitting hard in the truck box. Maybe ill make one that alittle bigger
Old Sep 20, 2007 | 07:11 PM
  #59
BAD DNKY's Avatar
ok so got alot done today with the amp install. One question with the LOC. I have four wire and a ground. Can i double up the speaker wires (wrap the two positives and two negative together and run them into the single negative and single positive output of the OEM factory output for the OEM sub) to just the single output from the OEM amp? Do i have to ground the LOC?
Old Sep 20, 2007 | 08:11 PM
  #60
Tripnbeats's Avatar
no dont twist cables together on the loc.....use one channel on it and then split the rca cables.... dont connect the ground thats for other reasons (older cars)
Old Sep 20, 2007 | 09:00 PM
  #61
HQTL6SPD's Avatar
if i wanted to upgrade all my speakers and wiring with a box in the trunk, what is the best way to keep 5.1?
Old Sep 21, 2007 | 02:15 PM
  #62
BAD DNKY's Avatar
Can you attach the LOC and run OEM speakers at the same time?
Old Sep 22, 2007 | 01:37 PM
  #63
Tripnbeats's Avatar
"bad"..ur answer is nope...and HQ unless u have a 5channel amp and 3 LOCs or the 3sixty or the jl cleansweep.....the answer is no.....personally depending on how loud u wanna get u dont need 5.1 anymore....at this point i have 4.3 and its retarded. and im selling the 3 10w6's i was running and ordering 2 12w7 to save a lil weight (like .3 lbs) or i may just go with 2 10w7's....
AndrewS
19
Mar 14, 2024 06:59 PM
Feb 25, 2020 09:57 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
NSolace
Sep 3, 2015 08:02 PM
