Getting CDT CL-E61 6.5 components
Old Oct 2, 2007 | 03:13 PM
italian_spak's Avatar
im getting this set this week, already ordered everyting, components set with tweeters for 130$ CAN
specs:
Improved with EX-450 24 dB Elliptic 2-way xover
• Upgraded with TW-25s 1"silk Tweeter
• Improved overall system power handling
Midrange: 6.5" slim neodymium magnet design
Cone: Mix Fabric Fiber Glass
Crossover:EX-450 2-way Elliptic 4th/5th order
Tweeter: TW-25 1" Smooth Silk Dome
Surface & flush mount housings
Power Handling: 150 watt RMS @ 120Hz high pass
Frequency Response: 6-20kHz
Sensitivity: 91.8 dB
Impedance: 4 Ohm
Old Oct 3, 2007 | 04:04 PM
re
anyone got comments on this set??
Old Oct 4, 2007 | 07:45 AM
rodneyc77's Avatar
Retired!!! ON TOP!!!
sounds like a great deal... how much power are going to throw at them... make it sufficient 'cause they like alot of power...
Old Oct 5, 2007 | 05:54 PM
re
well rodney right now im gonna start by installing them, and then ill see if i need or not to add a 2ch amp
btw how many wrms is the oem 4ch amp shooting out?
i still dont know how to remove the oem tweeters....
Old Oct 5, 2007 | 08:39 PM
King of Pain's Avatar
CDTs are some of the best speakers around. I love my set. They do take alot of power to really make them sing. The OEM amp won't be enough.
Insert a screwdriver on the side of the tweeter and gently pull up, it will pop off.
Old Oct 5, 2007 | 10:54 PM
crazymonkeytl's Avatar
looks kinda clean lol :o woot woot
Old Oct 7, 2007 | 07:29 PM
re
Thanks for the great picture, i will install the set this week and see how it sounds...can anyone explain to me the easiest way to hookup a 2CH amp?
Old Dec 1, 2007 | 02:35 PM
re
Been so busy havent installed anything yet, but this week i will and i tried searching for the diy concerning the front door panel removal and cannot find it can anyone pls post the link here
thanks boys
Old Dec 1, 2007 | 03:47 PM
4 Screws hold the panel in place.
Behind the silver door release handle are 2 screws. They're behind the plastic cover
Along the bottom of the door pull handle is a small hole with another screw.
The black rubber door stop has another screw.
That's it. remove those and gently pull the panel off. I usually start pulling the bottom portion first and make my way up the panel.
Here's the link to the diagram
https://acurazine.com/forums/car-talk-5/my-car-super-street-143797/
Old Dec 2, 2007 | 11:47 AM
re
thanks bro, i also wanted to ask if the oem tweeter wires start off from the front speakers or they come right off the stock amp?
mlody
Dec 4, 2019 02:11 PM
Jul 16, 2017 07:33 AM
brboy
Oct 5, 2015 11:34 AM
polish_pat
Sep 25, 2015 12:24 PM
