Gauge/Amp Power Wire
Old Mar 2, 2011 | 01:16 PM
Comptechtl2367's Avatar
I have spent about 2 hours searching this forum for how people are hooking up their gagues power wire and also what people tap into to run the amp ref wire.
I know some people just tap an empty spot in the fuse box but i was not sure about how safe that is but i willing to do it if there is no other way. Thanks in advance, if there are threads about this sorry just link them on here and ill figure it out!
Old Mar 2, 2011 | 01:37 PM
wanting to know how big of a gauge of power wire to go? depends on what you're pushing.
8gauge will get the job done.
4gauge will get the job done.
0gauge will get the job done.
one of them is underkill and the other overkill.
and most ppl use fuse #32 for the remote wire. you have to buy an add a fuse from autozone or the like...
Old Mar 2, 2011 | 02:00 PM
That is perfect! Thank you i will go buy one right now!
Old Mar 3, 2011 | 09:28 AM
jda123's Avatar
Dogmatic Dinosaur
Post the specs of your amp(s) and you can get some power wire gauge suggestions.
Your power needs to be run from your batter. The negative from a soild position in the trunk somewhere. The remote will work great with an add-a-fuse as posted above.
Old Mar 9, 2011 | 07:10 AM
veejay863's Avatar
3rd Gear
New member in the building! Just bought a 08 TL with navi last week. I plan on running my amp and subs to the stock radio and I also have the same question as OP. Here is the amp that I will be pushing http://www.kenwoodusa.com/Car_Entert...iers/KAC-8105D. I went to Best Buy and they told me I would need a 8 gauge wire, but they didnt tell me how many watts is should be. I've also heard the lower the gauge, the better. Can somebody help me out?
Old Mar 9, 2011 | 07:54 AM
JDM RICe's Avatar
8 gauge should do.
Old Mar 9, 2011 | 08:10 AM
stvtec's Avatar
'06 WDP TL 6MT
Yeah but he needs to know how many watts.
j/p good luck and post up pics of the install
Old Mar 9, 2011 | 08:41 AM
jda123's Avatar
Dogmatic Dinosaur
8 would be fine for that single amp. If you want a pair of amps, then put in a 4 gauge dual amp kit. When you get a kit, it would be better if it is Oxygen free copper.
Old Mar 9, 2011 | 09:01 AM
HEAVY_RL's Avatar
Not sure how geeked you want to be on this, but the main rule is what amount of amperage you want the wire to carry with out melting.
I pulled this off the net:
Gauge 12 Volts
22 5A
20 8A
18 10A
16 20A
14 40A
12 60A
10 100A
8 150A
Then use the appropriate fuse/circuit breaker size to protect the system.
Old Mar 9, 2011 | 09:06 AM
veejay863's Avatar
3rd Gear
Im a newbie to this whole stereo install thing lol.
So it doesnt matter how many watts the cable is?
Old Mar 9, 2011 | 09:25 AM
rockstar143's Avatar
Cable doesn't have watts...watts is the draw of electricity...you just have to make sure the cable it big enough to handle the AMPERAGE (watts x volts = amps...IIRC).
So if you pull thru too much juice into a small wire, it'll melt.
Just add up the AMP fuses and get a wire that's big enough for it.
EX:
My sub amp has 2 60AMP fuses and my mids/high amp has 1 60AMP Fuse, so you want your main to be able to handle ABOUT 180 AMPS (although that's a safety MAX you'll never likely hit).
Old Mar 9, 2011 | 09:57 AM
veejay863's Avatar
3rd Gear
Cool, got it. Appreciate it fellas!
Old Mar 29, 2011 | 12:44 PM
Bearcat557's Avatar
watts/volts = amps
Acura604
20
Aug 5, 2017 12:55 AM
Jul 16, 2017 07:33 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
