FYT Tesla Style Head Unit - Navitech, etc. UIS7862 - Launcher, tbd
I modified the launcher from Mekede's Tesla FYT unit to have our Acura TL 3G in Anthracite Gray. I updated my Navitech unit with a Mekede rom but this launcher should work with the original one it came with as well. Just put it on an usb and install it like any other apk. GooglePlay Protect might give you a warning but it's literally just the Mekede Launcher59 with one image changed. I will be adding more in the future.
**The blank space by the music widget is integrated space you can edit in settings. I typically use Maps there but it supports others. I just didn't have it set up in the pic.** Launcher59_AcuraTL3G
If you need any other model or prefer a different paint color, let me know and I will make more variations.
Big thanks for creating this launcher, I have the larger 12.1in screen that Navitech now sells and I was able to load this .apk in there.
Two questions I had though;
1. Does anyone know if it is possible to add another row of app icons? Either through settings or editing the .apk source files? Because the 12.1in doesn't have physical buttons it is tall enough for there to be enough real estate for another row of apps.
2. Where in settings do I need to go in order to set the top right tile to an app? I'd like to set it to be maps or something, but I can't seem to find a way to do that.
Also if anyone else is interested, I created a launcher image for a black Type S with the anthracite waffles.
