fuse box spot to use?
Old Mar 18, 2005 | 08:15 AM
AdamNJ's Avatar
Make MyTL Great Again
Question fuse box spot to use?
I know there are a few open spots inside the fuse box on the driver side. Are these spots safe to use? Does anyone know what type of power each free spot gives off? Also is there a limit to the AMPs that can be pulled from one of these spots/what is the recommended fuse size?
I'm looking for a spot that has power only when the car is in accessory or started.
Thanks.
Old Mar 18, 2005 | 08:29 AM
cM3go's Avatar
the Fuse box cover will have the amperage for each spot. There are 2 Aux fuse spots that are open. I believe they are called ACC 1 and ACC 2. ACC = accessory
Old Mar 18, 2005 | 12:45 PM
AdamNJ's Avatar
I was actually talking about #3 and #12 which the manual says is "not used" and the fuse box cover just has that spot blank. I did not realize other available spots existed until I read your post and then looked at my car.
Here is what I found:
#29 (7.5A) IG OP1
#31 (7.5A) IG OP2
#33 (7.5A) HAC OP
So my guess is that you are talking about #29 & #31. Does anyone know when there is power at #29 & #31, is it only while the car is running, accessory? Also what is #33? Constant power?
ITSJESTER
17
Dec 6, 2018 02:29 AM
Acura604
20
Aug 5, 2017 12:55 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
dirleton
Sep 28, 2015 07:05 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
