Fot those w/ Infinity Tweeters
just got my 1011t tweets. When you folks installed them did you use the infinity corssover or did you just swap in the tweets.
Also tried to search but I'm not sure the search feature is working correctly on the new site.
I used the supplied inline crossover. You will kill them without it.
The DVD-A Script Guy
Use the crossovers supplied with the tweets. The OE has a capacitor glues to the tweeter so when you remove the OE tweeter, out comes the crossover.
Plus, the 1011t comes with a reasonable quality second order crossover (the stock capacitor is a 1st order filter). The infinity crossover cuts corners by using solid core inductors but it does a decent job. Second order filters aren't always "better" than first order but in this case I'd stick with the infinity supplied one. I have the 1011ts in mt TL and that's what I did.
You may also choose to upgrade you center channel speaker as well. Many chose another infinity driver but when I looked none had silk dome tweeters. I chose the 1011ts since I prefer silk (textile) tweeters. I eventually found a Boston Acoustics driver for the center. Selling the left over on the forum was easy and resulted in 2 A-ziners getting a good deal (me and the other guy!)
Ref this thread -->https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/another-tweeter-center-channel-upgrade-604804/ It has lots of good info on wiring and mounting the stuff.
akbears15
15
11-05-2015 07:06 AM
sockr1
10-01-2015 01:31 AM
pistacio
09-26-2015 09:45 AM
4drviper
09-23-2015 09:00 PM
