FM Reception Issues
Old Aug 22, 2007 | 05:52 PM
tejesh83's Avatar
FM Reception Issues
Ever since installing new amps and a carpc with NAVI touchscreen hack, I've had horrible FM reception in my car. Stations which used to come in clear before, always have some static now. I think I may have shook loose a connector or pinched the antennae cable somewhere. Last time I had the radio out, I made sure the antennae connectors was plugged in fully, but I still have this issue.
Any ideas what the problem(s) could be and how to fix them? Is there a connector near the rear deck? Maybe it shook loose when I installed new speakers back there. Also, when removing the radio, I wonder if the cable got pinched or damaged since its a tight fit back there. Maybe I should try replacing the antennae cables up there. Anyone else have experience with this and have some thoughts to share?
Old Aug 23, 2007 | 03:30 AM
datmrman's Avatar
You should check out this thread: HELP I cut a wired behind my stereo during a DVD install!!
Old Aug 24, 2007 | 08:53 AM
tejesh83's Avatar
Thanks dat!
I think I may try replacing that cable he accidentally cut to. When pulling the radio out a few times, I unitentionally put a lot of stress on it, so it may have become damaged. Plus, its only $12, so its worth a shot.
-TJ
Frathora
Sep 28, 2015 11:29 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
carz0159
Sep 20, 2015 06:11 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
vanderveen44
ILX
Sep 2, 2015 01:48 PM
