Fixing Trunk Rattle From Sub
Old Mar 21, 2009 | 01:40 PM
lucnex's Avatar
Where Did My Garage Go?!!
I just had two 12 inch Alpine SWR-1222D's installed yesterday into a sealed enclosure. Bass sounds amazing but trunk rattles like crazy. Its not the license plate but the area around it where the license plate lights are (that gray area). I pressed on that and it stopped significantly. What I'm wondering is what will stop it completely? I dont want to buy Dynamat unless I know its gonna work, but if thats the best solution I surely would. Anyone have a suggestions?
Old Mar 21, 2009 | 05:42 PM
sue bee's Avatar
Dynamat will work. Make sure you get the extreme version or whatever. Not only will it work, but it will sound much better. You'll be surprised. Also, don't forget to get a dynamat license plate kit, too.
Old Mar 21, 2009 | 06:10 PM
DoostyTL's Avatar
i get a rattling from my factory sub haha
Old Mar 21, 2009 | 10:03 PM
BukvaMan's Avatar
for the license plate just put some weather seal behind it and thats it.
Old Mar 23, 2009 | 10:19 AM
lucnex's Avatar
is this an easy install? Anyone have it done by a shop...I dont wanna pay them to do easy labor
Old Mar 23, 2009 | 02:08 PM
pilotman28's Avatar
I'd use rubber washers if it's just your license plate. If it's not then yes you can remove EVERYTHING out of your trunk and put down a healthy helping of dynamat or the like. If you can use a sticker then you can put down dynamat.
Old Mar 23, 2009 | 05:22 PM
DGP-King's Avatar
B A N N E D
Dynamat works great! had it in my 06 CTS
costd me 200 bucks for the dynamat n install Good luck!!
Old Mar 24, 2009 | 01:22 AM
Nick337's Avatar
i would like to know also.
Old Apr 1, 2009 | 12:23 PM
lucnex's Avatar
i figure this is easy enough to do yourself. Is taking out the rear deck harD?
Old Apr 1, 2009 | 02:41 PM
TeknoKing's Avatar
The procedure is not hard at all, but it is time consuming.
Make sure to purchase a roller...otherwise don't bother. The dynamat must be applied with care to cover all the crevices. The trunk lid is the main culprit. The rear deck is the 2nd, and the entire trunk side and bottom are the 3rd. This WILL weigh down your car.
Old Apr 2, 2009 | 10:56 AM
Tripnbeats's Avatar
my trunk doesnt stay up with the amount of dampening material i have on it....but it doesnt vibrate anymoooorreeee lol
Old Apr 2, 2009 | 08:50 PM
fade2blk's Avatar
then check this out
http://www.dynamat.com/faqs_faqs.html
Old Apr 2, 2009 | 09:42 PM
Fresh23's Avatar
or this https://acurazine.com/forums/3g-tl-problems-fixes-114/rear-deck-bass-rattle-fix-%5Bpics-video%5D-614680/
Old Apr 3, 2009 | 02:00 AM
Nick337's Avatar
Originally Posted by fade2blk
I have the dynamat already, its all matted up, just trying to figure out how to get the section behind the plate to stop rattling
Old Apr 4, 2009 | 01:02 PM
Type S Fanatic's Avatar
Make sure to use rubbing alcohol to clean any dirty areas like around the wheel wells before you apply the dynamat so that you make sure you get a good adhesion.
Old Apr 4, 2009 | 10:08 PM
lucnex's Avatar
I know...but a entire bulk pack of dynamat extreme is only 20 pounds....and thats with 36 square feet. The trunk only requires about 22 feet tops...I dont see it making that much of a difference. Luckily I have a heavier spring in my trunk since I have a decklid spoiler
marcelft
Jul 10, 2018 06:17 PM
BoricuaTL
Apr 8, 2016 01:08 PM
mugen_kid
Nov 13, 2015 10:38 PM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
3GTLOwns
Sep 9, 2015 09:51 PM
