Finally got some pics of my stereo install.
Speed Addict
Have had this in for a month or so, but one of the amps stopped working. Turned out the voltage on the LOC was too high causing the amp to go into protection. Got it back from the factory yesterday and re-installed... It sounds pretty sweet now. Amp dialed in 1605 watts at 2 ohms though, only rated at 1400.
Speed Addict
Originally Posted by bklynpanman
what is that under your amps and over your spare tire.. and what kind of wood did you use for the cover..
Originally Posted by Darkcyde024
very sweet install... how's loud is the bass?? what kinda sub is that?? I was thinking of doing a single sub setup, I just can't figure out what kind of woofer I should go with
Speed Addict
Originally Posted by tfe691
Looks good. Watch out for those phoenix gold amps and over heating. i just got rid of my ti's for that reason.
The bass, Darkcyde, is DAMN loud. The sub is a 12W7. The installer said I should be in the mid 140s dB wise, and I do not doubt it. The sub is 47 lbs without the box, and the design of the sub with the reverse surround actually makes the sub a little over 13"s... it sounds like an accurate 15". Highly recommend any JL, esp the W6 series and the W7.
140db?? Hope you can still hear in a few years. Don't laugh...my hearing has been damaged from flying jet aircraft even using noise canceling headphones. Once it's gone it never comes back to normal...I know!! I hate saying "huh?"....when I'm talking to people but it's the result of my hearing loss. I'd estimate the SPL in the aircraft I fly to be in the constant 85db range.....with occasional levels at 90-100db and even that was enough to damage my hearing in less than 5 years using headphones with active noise canceling circuits built into the headset. I'm not trying to criticize you for having a nice stereo setup in your car...just be carefull with the volume...I'd hate to see you damage your ears like I've done with mine.
I'm sorry to hear that jet!! that sux. i personally know audiophiles who play there car stereos at high volumes constantly and have had no hearing loss at all. I agree that moderation is key but not everyones ears are the same. EVERYONE SHOULD USE CAUTION though.
what i wonder is the frequency range of the noise you hear and that of the subwoofers. I'd image the jet aircraft would be at a much higher frequency than the subs which usually play no higher than 2-300 hz. would that have an affect on how your ears react to the sound?!?!?
did you keep your factory speakers in the doors and what not??
I am looking into the W7 myself with the same type of set up, if you don't mind me asking, how much did the whole set up run you?? Just want an idea.........ballpark would be good. Thanks.
Speed Addict
Jet, yes I know all about hearing loss. I think I may have a little hearing loss, but have had a stereo since the day I was driving, 16 years, 0 days. I had a 140+ dB stereo in my first car, and it atucally used to make my heart skip beats sometimes, that wasn't cool. The bass rythmic hitting can actually cause your heart to skip beats, which I thought was non-sense till it happened to me a few times in that car. My car after that measured 147dB with the gains all the way down, it had 152 in it, I am positive, but I never tested it when I turned the gains up to full voltage. The one after that only hit 136 till it blew a fuse, it wasn't as loud, but sounded a lit better. So yea, I've had loud stereos almost half my life, and all my driving life, so I am being careful with the volume.
Speed Addict
I'm sure you used 3 loc's so that you could keep your 5.1. but why not just get an audio control lc6... wouldn't that work for all six channels? i was thinking about getting it
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
