finally got my system hooked up but...
Old Oct 16, 2010 | 06:39 PM
blunted sean's Avatar
after weeks of putting it off i finaly hooked up my system. i had a local install place set it up n i couldnt be more happy about how it came out, but now i need to get my nav code that i cant find anywhere in or on the car, i just have to wait till tomorrow on acura.com
Next will be tinting my tails n side markers then an exaust!!
(soon i hope)
Old Oct 16, 2010 | 09:01 PM
eduardmc's Avatar
Acura TL 04, G37s 19"
(soon i hope)
Do you have any pic of the installation.
Start doing your research because this is where all the fun part will begin. i had never install a system until i got my tl (9 month ago) i can now say that i could install any system and i thought it was the hardest thing on earth. Today i finish my installation (upgrading again) alpine pdx 1000 and pdx 4.150 running a 0 gauge wire and installing my jl 12w7 in a ported box 2cubit port tune 30hz. set my 4 channel gain by hear and my mono amp using a multimeter to achive around 55v which is the require 1000rms X 3ohm with my volume at 30. After tunning everything with my 3sixty is sounding really good since i have a good front stage with my boston pro60 active. I have my front component crossover at 80hz.
Old Oct 16, 2010 | 09:07 PM
It's nothing special. I got a JL 500/1 hooked up to a 12" kicker L7. I'll post some pics Tomorrow
Old Oct 17, 2010 | 06:46 PM
Help with serial code
I'm trying to get my serial code so I can get my nav code. I saw on the Acura site a diagram of holding the 1 & 6 then hitting power. For some reason this is wrking for me. Any advise?
Old Oct 17, 2010 | 07:06 PM
wahshi's Avatar
My TL loves summer
Try these...
https://acurazine.com/forums/3g-tl-2004-2008-93/need-help-please-radio-code-runaround-3g-garage-i-091-a-552399/
https://acurazine.com/forums/2g-cl-frequently-asked-questions-52/radio-code-solution-here-3g-garage-i-091-a-469527/
Old Oct 17, 2010 | 08:43 PM
It gave me more info on the subjet but still cant figure it out. The radio is working but not the nav. I've looked eveywhere in the car. Stil nothing. I hope I don't need the serial number when calling Acura
Old Oct 17, 2010 | 08:56 PM
ggesq's Avatar
threads merged.
Old Oct 17, 2010 | 11:07 PM
jptl04's Avatar
Bone stock tl-s
the serial number is on the bottom of the dvd drive in the trunk. just unscrew the 4 bolts holding it down.
Old Oct 17, 2010 | 11:56 PM
zerolq's Avatar
Nom Nom Nom!
My nav code was handwritten in the maintence manual. On the check off list when I purchased the car.
Old Oct 18, 2010 | 01:20 AM
Trunk Monkey's Avatar
Coolest A-zine Member
Is it not the #'s on the glove box? If not, what are those?
Old Oct 18, 2010 | 09:09 AM
Not on the glove box. I'll just rip the nav try out n get it that way
Old Oct 18, 2010 | 03:06 PM
dhong87's Avatar
no no no no no no no stop.
dont rip out the navi..
go to your trunk.. look for the navi unit there... slide a mirror underneath and the serial numbers should be right there.. if needed, unscrew the navi unit so that you can see the serial numbers.
Old Oct 18, 2010 | 03:52 PM
zerolq's Avatar
Nom Nom Nom!
That's for the radio code. Just take it to the dealership and they can look up ur nav code if you can't find it. That's how I found out where my code was written down.
Old Oct 18, 2010 | 05:09 PM
just started a new thread that i should have added in here, i didnt rip my nav out i riped the trunk open but no serial num.
Old Oct 18, 2010 | 05:37 PM
I got the code. man i couldnt be happier to use my nav again. now off to put my trunk back together
cycdaniel
Dec 17, 2019 10:58 AM
jspangan
ILX
19
Aug 30, 2016 05:37 PM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
usual suspect
2G TSX Photograph Gallery
Dec 7, 2015 10:52 AM
