View Poll Results: best to dynamat or not????
yes dynamat trunk
62.50%
no dont dynamat
0%
no dont dynamat just do this..........
37.50%
Voters: 8. You may not vote on this poll
Dynamat or not??
Old Apr 23, 2012 | 01:06 PM
Westside_TL's Avatar
Dynamat or not??
question to all that have and those thinking about it?? 07 tl base when added a sub in trunk should we add dynamat to the trunk or no or try something totaly different?? also note this is for trunk rattle not back dash that problem fix thanks to great people here!!!
Old Apr 23, 2012 | 01:08 PM
SharksBreath's Avatar
BANNED
second skin is a little better and easier to use than dynamat.
i would recommend it for sure. one tip, try and pinpoint exactly where the rattles are coming from before you start laying the stuff down. it works great tho...good stuff. make sure you get the roller tool as well. makes laying the stuff down a breeze.
Old Apr 23, 2012 | 01:26 PM
so ur vote is option 3?
Old Apr 23, 2012 | 01:28 PM
maharajamd's Avatar
http://www.secondskinaudio.com/
Damplifier then Overkill. Luxury Liner on the doors, roof, floor.
Old Apr 23, 2012 | 01:31 PM
BANNED
what options?
oh i see it's a poll...gotcha.
Old Apr 23, 2012 | 04:39 PM
but the question was for trunk not whole car
Old Apr 23, 2012 | 04:43 PM
maharajamd's Avatar
Then it's pretty much just the Damplifier.
Old Apr 23, 2012 | 04:44 PM
Trunk Monkey's Avatar
Coolest A-zine Member
Sound Deadener Showdown CLD Tiles or Second Skin Damplifier Pro
Like said before, play music and listen for rattles, then attack that location. Flat surfaces are where you get rattles/resonance, not curves.
Old Apr 23, 2012 | 06:03 PM
I hate cars's Avatar
I've had great luck with both Second Skin and Dynamat but the second skin seems to work slightly better for a given weight.
For the trunk, removing the license plate frame and using all 4 screws for the plate will take care of most of the rattles. I would to this first and see if you still need it.
Old Apr 23, 2012 | 07:15 PM
Mug's Avatar
Mug
I thought I read somewhere on here that it could be the counter weight under the trunk lid liner that rattles too.
AcuraKidd
Apr 23, 2007 06:33 PM
digital_04
Sep 16, 2006 11:32 PM
ASuddenSilence
Jul 17, 2005 06:15 PM
ReflexRacing_com
Oct 24, 2002 12:49 AM
ZeroPSI
Jun 20, 2002 05:22 PM
