DVD-A Problem
Old Jan 17, 2009 | 09:15 PM
mrempp's Avatar
DVD-A Problem
Lets see if any one can help me with this issue i'm having. I have a 5.1 DVD i'm trying to convert to a DVD-a. I have used both dvd decrypter and dvd audio extractor to extract the audio files. I have used both audio solo, and wavelab to try to burn the dvd-a. The wave files play fine on my computer, but not so well in the car. When i go to play it in the car it plays for about 15 seconds, and then the audio cuts out and the time keeps going. If i fast forward the audio it starts playing fine again for about another 15 seconds then does the same thing. I can skip to the next track and it does the same thing, plays for 15 seconds or so and then stops, but the time keeps going. But i can always fast forward just a second and it will play fine for another 15 seconds. What the hell is wrong. I have burnt 3 dvd's using different settings and it does the same thing. any help would be appreciated.
Old Jan 17, 2009 | 09:31 PM
Bearcat94's Avatar
AZ Community Team
Its a copy protection scheme.
The DVD Audio portion has a watermark. That means some code is imbedded into the wav files at ~15 second intervals.
When you made a copy you removed the original encryption but left the watermark (you cannot, ever, remove the watermark).
No Encryption + Watermark = copied DVD; TL will not play it.
There are a handful of players that ignore watermarks. They are mostly (all?) home systems. The Alpine unit in the TL does nto ignore the watermark.
Do a google search for "Watermark DVD-Audio" and/or similar terms - lots of info out there, but no solutions.
Also, check this thread: https://acurazine.com/forums/showthr...300&highlight=
Old Jan 17, 2009 | 09:49 PM
mrempp's Avatar
alright thanks for the response. I just went ahead and bought a used copy of the dvd-a for $10 off amazon
Old Jan 20, 2009 | 03:07 AM
Sal's Type S's Avatar
Freakin Bastards can't we save a buck.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
