DVD-A Disc's Questions
So I tried the Freeware from Adobeman and was able to create the ISO image. Let me know if I am wrong, but I want to burn the file as an Image correct? I used Roxio and it did not work for me? What am I doing wrong? Do I need to use Nero to burn this image?
now with four rings
yes, you want to burn the file as an image...i use Roxio Toast Titanium all day to burn DVD-A ISO files with no problem...but i use a Mac...
check the file size of your ISO image...it should be fairly large...if it's not, then it wasn't made correctly...
you can also use Nero to burn your image file...on windows, i prefer that over Roxio anything...
also, check out my signature to download the Definitive DVD-Audio Guide v2.0...
Thanks for the help. I will need to get a better copy of Nero for my computer. Roxio did not work for me. The file size is 3.77gb so the conversion was correct just not the burn process but I have had issues with the burner on my laptop in the past making regular CD-
Audio disc's. Thanks again
How to switch Groups in the DVD Audio??
Hello All,
I am amazed of what the sound of DVD Audio, thanks to Adobeman!!
Anyway, I burned a few more DVD-A using DVD Audio Solo. When I created the DVD, I made 4 groups within the DVD. But when I inserted the DVD in my TL, it only played the 1st group. Does anyone know how I can jump to the 2nd or 3rd group within the DAV-A disc ??
now with four rings
What is the benefit of the DVD-A's? I burned about 6 DVD-A's and also burned the same songs as MP3's to one DISC. I have listened to both and I do not hear any difference. For me the MP3 DISC's allow the Dolby function to work; while the DVD-A's do not.
now with four rings
if you have an '07+ TL or an mp3 deck, don't bother with burning DVD-A discs...it benefits us who don't have an mp3 deck and only the stock DVD-A one...
but, if you want some quick info on the benefit regardless: with an mp3 you're listening to a compressed audio file...a DVD-A file is uncompressed, and therefore retains higher quality...turning the music up on an mp3 will give you distortion whereas a DVD-A is very very clear...plus with commercial DVD-A discs, you can hear every single instrument being played on a surround sound setup...the audio is crystal clear and it sounds like you're really there listening to the artist in person...you should try it out for yourself...
I used Adobeman and able to convert songs into 5.1 .WAV file.
But my question is can I use MP3 files to convert to 5.1 file? I made MP3 to WAV, then converted into 5.1 WAV using Adobeman's software.. Because when I add files to DVD audio Solo to burn the files... error messages showed on the right message bar. Unsupported or corrupted.....
I thought I follow the instructions on this site to make a DVD A disk... but what am I doing wrong??? HELP
now with four rings
cellowiz, WAVs can be very picky sometimes...they have quite a few settings and one little thing can ruin your disc...your best bet is to convert to a FLAC file, not WAV...FLAC never fails...
08' WDP Type S
now with four rings
Originally Posted by PSURob12
Where could one find a commercial DVD-A disk? I'd love to try a few out.
http://store.acousticsounds.com/cate...ds=g_dvd_audio
http://www.5point1.com/index2.html
http://www.cduniverse.com/browsecat.asp?cat=1028 (where i bought mine)
i dont understand what i'm doing wrong. I've used the adobeman dvd-a program but the dvd audio disc are just being spit right back out by my TL. I followed the instruction to the dot and tried multiple discs but yield no results. Is it my media? I've tried using 2 different types of DVD+R and none works.
The +R didn't work for me. The -R work fine.
One quick question while I'm here. At first, the DVD-A I create using Adobemans software work fine. Then, over time, some of the tracks just end abruptly. Anyone else have this problem?
now with four rings
also, if any of you haven't already, check out the Definitive DVD-Audio Guide v2.0 in my signature...it should answer many of your questions...
08' WDP Type S
now with four rings
So since I have an 08', I won't get any benefit from burning a DVD-A disc?
now if you buy a commercial DVD-A disc, then yes, you'll notice the difference...
now with four rings
i've only got Crystal Method - Legion of Boom and Porcupine Tree - In Absentia on DVA-A discs, but they are awesome!
you can hear every single instrument on the Porcupine Tree disc...as if you were there on stage with them...and the Legion of Boom is just badass...
now with four rings
haha...awesome!
porcupine tree is called progressive rock...whatever that is...
http://en.wikipedia.org/wiki/Porcupine_Tree
http://www.porcupinetree.com/
SidhuSaaB
05-30-2020 12:40 AM
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
