DVD-Audio - need help burning AUDIO_TS
Old Aug 21, 2005 | 03:27 PM
triggle's Avatar
'04 6mt Pearl
Question DVD-Audio - need help burning AUDIO_TS
Can anyone guide me to burn the AUDIO_TS and VIDEO_TS folders I've captured to my HD, to a DVD/R ?
I've burned the folders as a DVD-V with Nero and it works in a home DVD player, but not in the TL as a DVDA, even though it did burn the contents of the AUDIO_TS folder.
I'd like to know if there is any tools like discwelder or wavelab or something from doom9.net that can create an ISO from those folders. I looked into DVDAUTHOR scripts but it appeared to me I need to know the start sector for the MKISOFS to create an ISO.
Old Aug 21, 2005 | 07:04 PM
Adobeman's Avatar
The DVD-A Script Guy
Yeah, the start sector thing is critical to the process I scripted. From what I have seen it is needed for audio-only players like the one in the TL. You need to make the image the first time (mkisofs) so that you can instruct dvda-author (via the start sector) where to "tell" audio-only players how to correctly read the disk in the second path.
If it is DVD-V content the it probably will be pretty hard to just put in the audio_ts dir. DVD-A files (.aob) are different than their brethren video (vob) files.
If you are trying to take multichannel audio from within vob files and then make a multichannel dvd-a then freeware is going to be tough to use. Most everything I have seen involves some pricey but good tools.
I'm guessing there is a content problem since you should, in theory, be able to burn audio_ts and video_ts structures to disk without an intermediate ISO step.
What exactly are you trying to do (if you don't mind telling)?
Old Aug 22, 2005 | 02:37 AM
triggle's Avatar
'04 6mt Pearl
I have a DVDA which I am attempting to back up to a DVD/R. Using some utilities I created a clean copy of the AUDIO_TS and VIDEO_TS on the HD.
Now I am stuck as to how to burn it. Nero burns as a DVD-V but the DVDA part doesn't work.
I can pull out the mlp files but I'd rather have the whole disk backed up.
Old Aug 22, 2005 | 08:22 AM
PhilB's Avatar
'05 DGP/Parch 5AT Navi
My understanding is that DVD-A uses a differenct encryption then DVD-V. The DVD-A encryption has not yet been cracked (probably not much demand for it since DVD-A is such a dud). Thus, I don't think you're gettting the DVD-A files off of the disc. If you are sure you have the DVD-A files and not the dolby digital tracks from the DVD-V section please correct me.
If you are burning only the dolby tracks, that would explain why the TL can't play the disc but a stand-alone player can.
-phil
Old Aug 22, 2005 | 03:33 PM
Adobeman's Avatar
-phil
Different encryption ...Yes
Not cracked...not exactly true anymore.
I'm guessing triggle knows what "not exactly true anymore" means and that he also used WinDVD 6 is some way to do so. (nudge, nudge, wink, wink). But he's missing something that we can't put our fingers on.
Old Aug 24, 2005 | 03:39 AM
triggle's Avatar
'04 6mt Pearl
Adobeman is correct.
I was hoping that Wavelab or Discwelder could burn the Audio_ts folder. I am checking the docs for discwelder to see if it can fit the bill. It is too bad those programs seem to prefer proprietary file formats or extensions.
calrow
May 3, 2017 10:21 PM
knight rider
Mar 4, 2016 08:59 AM
Thuneau
Oct 3, 2015 04:19 PM
