Dual Disc
Old Nov 9, 2004 | 06:40 PM
Penguin's Avatar
Dual Disc
Has any of you been brave enough to stick one these thick disks into the player? I have had to take apart a slot loaded player before, because a thick disk got stuck in it. I would not be looking forward doing the same to my changer in the TL.
dee
;-D
Old Nov 9, 2004 | 07:03 PM
Road Rage's Avatar
Not a Blowhole
Anyone besides me not have a clue what he is asking?
Old Nov 9, 2004 | 07:09 PM
Ron A's Avatar
Administrator
That's why questions like these need to be posted in BT/Navi/Audio/Video where there are people more likely to understand this kind of stuff.
Anyway, I didn't know dual discs were thicker, I just thought they had stuff on both sides or had two layers of stuff on one side, so you can see how much I know about this.
Old Nov 9, 2004 | 07:57 PM
92NSX's Avatar
I know that if you put a label on a CD after you burn it, you may run into clearance issues. The paper used for labels is pretty thick.
Maybe that is what he is talking about.
Old Nov 9, 2004 | 08:00 PM
ricwilson's Avatar
Dual Discs work fine
Dual Discs are just a tiny bit thicker than a standard CD or DVD, but extensive testing has shown very few problems, and by personal experience, I can tell you that all the Dual Discs that I have tested (10 so far) work great in the TL. ric
Old Nov 9, 2004 | 08:04 PM
92NSX's Avatar
I have never heard of these. Are they a new type of music format? If so, what are the pros/cons to them if any?
Old Nov 9, 2004 | 10:27 PM
Penguin's Avatar
Sorry should have posted in the right sub forum. Dual disc is 25% thicker than regular CDs. The spec for single CDs and DVDs is 1.2 mm while dual disk is 1.5 mm. I had problems with some slot loaded home players with extra thick disk. The paper is a different issue. The paper causes the rollers to slip that is why it will not eject. ;-). BTW Dual disc, is just a marketing gimmic in my mind it is a sub-standard cd layer stuck to the backl of a DVD disk. The DVD can be video or audio. Technically it is a real bad idea but i am afraid this is the direction the music industry is going as far as DVD-A is concerned. The more elegant solution is what the SACD people did with hibryd SACDs, where there is a transparent CD layer in front of the DVD layer. Depending of the focus depth the laser can read the CD or the DVD layer.
dee
;-D
Old Nov 9, 2004 | 11:05 PM
orange-man's Avatar
My concern wasn't that the dualdisc wouldn't fit but rather that they would make it a DVD format to put some video content and not DVD-Audio which would make it useless in our players. I'm glad to know that ricwilson has tried some and they work. I didn't even know that 10 were released yet. That is a bit of a relief.
Old Nov 18, 2004 | 02:40 PM
ricwilson's Avatar
Want to try DualDisc?
Hi All,
If you've wanted to try DualDisc but can't find it in the stores, here is a good start - 45 titles released by Silverline:
DualDisc: http://www.dvdlauncher.com/search.php?browse=artist
DVD-Audio: http://www.silverlinerecords.com/catalog_main.asp
Enjoy, ric
SidhuSaaB
May 30, 2020 12:40 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
AcuraKidd
Sep 25, 2015 11:18 PM
