Drone from aftermarket sub
I’ve read about disconnecting the microphones but can’t find images of where. I have an 08 type S. Mine is a Canadian version if it matters. Is it the black thing by the rear dome lights or above the rear dome lights. Do I need to remove the front one too? I’ve read conflicting posts I found on here. Thanks for any help.
Where did you hook up your ground wire? If you piggy backed off the one in the trunk near the rear seats that can cause it. Know from experience lol. I didn’t disconnect any mics and just made a new ground position.
I used the seatbelt bolts. I disconnected the rear mic and my problem went away.
Ajgray1986 (12-20-2020)
515kbpUA7
12-07-2013 12:29 AM
TLGuy24
04-03-2009 11:46 AM
Puttinstankonia
03-09-2007 06:30 PM
