Driver 2 Keyfob will Lock and Unlock, but won't allow for Memory Seats?
Old Oct 2, 2012 | 10:55 PM
NFLblitze1's Avatar
Youse Gots Sacked
I lost my driver 1 key fob and have been having to use the driver 2 key fob, it unlocks and locks the doors, pops the trunk and will set off the alarm no problem. But i can't seem to get it to pair with the memory settings. i tried holding down the lock and unlock and waiting for the lights to blink twice. but it was a no go.
I recently got a remote start installed CompuStar if that means anything to anyone. Could this be causing my issue? am i not going through the steps properly?
Any help would be appreciated
Old Oct 3, 2012 | 11:14 AM
NFLblitze1's Avatar
Youse Gots Sacked
Anybody?
Old Oct 3, 2012 | 11:19 AM
terdonal's Avatar
Are you trying to pair with memory 2 or memory 1? If it is key fob 2 it has to be paired with memory 2.
Old Oct 3, 2012 | 05:55 PM
NFLblitze1's Avatar
Youse Gots Sacked
i can't pair it at all, i lost the driver 1 keyfob so im not trying to pair it with memory 1, i just want to pair it so i have memory 2 capabilities. do i need to re-link everything? because when i go into Memory Settings/Driver Settings in the little display on the dashboard it tells me you must link the driver 1 and driver 2 settings
Old Oct 3, 2012 | 10:46 PM
Will Y.'s Avatar
Registered but harmless
Have you set the DPMS using the memory 2 button on the door?
If not, do that first: select your preferred audio settings, then set the seat and mirror positions and put them into memory with door button #2.
Then try linking the remote.
Old Oct 4, 2012 | 01:59 AM
NFLblitze1's Avatar
Youse Gots Sacked
didn't work
Old Oct 6, 2012 | 12:26 AM
NFLblitze1's Avatar
Youse Gots Sacked
Bump anyone?
Old Oct 6, 2012 | 10:50 AM
Fulani has a TL's Avatar
What bypass did they use for the compustar? That could be the reason why it goes to Mem 1 automatically...
Old Oct 6, 2012 | 02:28 PM
NFLblitze1's Avatar
Youse Gots Sacked
im not sure, i had it installed professionally. So you are saying that maybe if i have the remote start uninstalled, and try to link up the mem2 remote, then re-hook up the remote start i shouldn't have any problems?
Old Oct 8, 2012 | 10:15 PM
NFLblitze1's Avatar
Youse Gots Sacked
bump?
Old Oct 15, 2012 | 10:33 AM
italiancip14's Avatar
free bump because I'm having the same issue, I'm sure other members did too. . .Actually, I guarantee it. So cmon guys help us out!!
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
tman570
Jun 11, 2019 07:56 AM
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
