Door speaker recommendations?
Old May 12, 2022 | 08:55 PM
Justin0104's Avatar
So been doing some research and i see the door speaker clearance in the 3g tl is very small, so i was wondering what some of y'all are using in there and what modifications if any that you had to do.
Old May 27, 2022 | 10:52 AM
Ratm68's Avatar
i replaced mine with infinity reference components, but i'm sure their 2-ways will work just fine as they're pretty identical. They come with a shallow magnet for clearance and their mounting adapter seems to be pretty compatible with with acuras, fit both the TL and MDX.
Old May 27, 2022 | 03:29 PM
kbouchard1092's Avatar
If you're keeping the OEM amplifier I would recommend getting a set of 2-ohm components. You will likely need to modify the OEM housing to fit, or buy adapters.
Old Jun 6, 2022 | 12:43 AM
pohljm's Avatar
use 1" spacer and trim whatever metal you need, you can fit very large mid's in that door
Old Sep 11, 2023 | 10:55 PM
hutt132's Avatar
I've been searching and still haven't seen anyone recommend a 2-ohm speaker for the doors.
Old Sep 20, 2023 | 11:37 PM
pohljm's Avatar
there are JBL's as well as some Infinity's that are 2 ohm
Old Dec 14, 2023 | 03:02 PM
vector1701's Avatar
Do you have any model #'s?
Old Dec 16, 2023 | 12:54 PM
pohljm's Avatar
Amazon Amazon
Click on hyperlink
Jerry Smith
May 31, 2020 10:41 AM
aameghoo
Jun 4, 2014 10:59 PM
zenmaster601
Aug 18, 2010 06:35 PM
paulonfiya
Oct 22, 2009 11:52 AM
