DOM’s Install Causing a Problem
Old Aug 24, 2010 | 07:08 AM
LostSol's Avatar
Chapter Leader (Central Florida)
OK so here’s what’s up. I installed my Dom’s unit on Sunday, got it to work properly, and everything seemed fine.
When I got in my car last night and my lights came on, I noticed a few of my HVAC buttons’ lights were out, specifically “OFF”, “DUAL”, “A/C”, ‘Recirculate’, and the passenger “AUTO”.
I checked all of the fuses that I could find related to the radio and HVAC system but couldn’t find any blown.
Any ideas?
Old Aug 24, 2010 | 06:45 PM
turbocivic94's Avatar
I never noticed any of the lights out except pass side heated seat switch light was not working. If under warr, just have the dealer replace them.
Old Aug 24, 2010 | 07:01 PM
LostSol's Avatar
Im quite sure showing up with a car with obviously modified wiring wont qualify under warranty
Old Aug 24, 2010 | 07:28 PM
csmeance's Avatar
Any ideas?
Where did you tap for power for dom's unit? Also did you make sure the harnesses were grounded properly?
Old Aug 24, 2010 | 07:35 PM
LostSol's Avatar
I used an add-a-circuit on fuse 32 as per the DIY. All grounds are solid as I used the factory ground point in the trunk.
Old Aug 26, 2010 | 07:31 AM
Greg D's Avatar
Any ideas?
Its the bulbs. There are a bunch of little micro bulbs that light up all those buttons. I had to replace several of them on my car at different times. You need to pull the screen out to change them. The OFF and DUAL are one bulb, AC and RECIRC are one bulb, and the AUTO is one bulb. Its most likely a coincidence that they burnt out around the time you installed the dom unit.
Old Aug 26, 2010 | 08:07 AM
LostSol's Avatar
So I got in my car this morning and the "A/C" and 'Recirculate' bulbs are working again.... This is the damndest thing.
Old Aug 26, 2010 | 08:17 AM
Greg D's Avatar
Mine did the same thing but it was the 2 fan speed buttons. If I hit the dash they would go on and off. Replaced the bulbs and never had the problem again.
Old Aug 26, 2010 | 08:20 AM
haha, stop lying to us lost!
what do you think your next plan of action will be? Have you checked out Roger555's LED conversion for all the buttons? its pretty sick!!!!
https://acurazine.com/forums/3g-tl-photograph-gallery-96/complete-led-conversion-789176/
Old Aug 26, 2010 | 08:25 AM
LostSol's Avatar
Plan of action for the moment is to continue to be a lazy bastard and see if the others come on by themselves!
But if it comes down to it I'll just have to start taking stuff apart.
As for an LED conversion, not gonna happen. I do not posess the skills or balls to attempt that mod.
Old Aug 26, 2010 | 06:14 PM
I'm gonna take mine to dealer to have them replace the heated seat switch. We will see what happens.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
bymotion
Nov 18, 2015 11:28 AM
darknite123
Integra
Aug 30, 2015 03:00 PM
