Does 07 TL w/Navi import any phonebooks?
I know the option is there, but it doesn't work with RAZR or many of the ones I checked online from Acura site.
It doesn't with my LG, either.
Go to handsfreelink.com for a list of phones that are supported. Wish I had done this before I bought my phone several weeks before taking delivery of my S.
Here's another limit: Whereas the nav system holds 1000 names 10K numbers, the MID only holds 50 which isn't much if you have a wide group of friends or if you use the car for business.
2012 Cadillac CTS-V Coupe
It's not a phone issue, it's the HFL system.
The HFL system doesn't have the ability to download address books. The only way it can be populated is by verbally (at least that's how it's in the RL) entring the voice tag and the number.
My Toyota Land Cruiser does what your asking, but the voice recognition/BT interface is so bad in that thing it makes me appreciate Acura's system so much more.
The '07 TL has a new feature called "Phone Book Access Profile" which is a new Bluetooth profile not yet included in many phones.
So far, only some Sony phones include the new profile.
Now, you mentioned "address books", not specifically "phone" books. Is this what you meant, or is there another feature of the nav you're referring to?
Originally Posted by violarx
No, not exactly, at least for the '07's. The main menu has an option for Cell Phones and, under that, for importing a cell phone book. Unfortunately, very few phones are supported.
So that must be new. I stand corrected.
It worked with my Sony T637 when I test drove the Type S last week. A very nice upgrade--even separates out the numbers by type (home, work, cel, fax) like my phone does. It took maybe 2 minutes for it to synch up. Will be deciding this week whether to go for the 07 TL-S or the 07 G35X--moving from my 04 TL, which has been the best car I have owned.
The TL 2007 does have the ability to import phonebookds into the Cellular phonebook of the HFL. However, most phones, except a few SonyErickson do not have the export/transfer capability. So, you are left to entering the phone numbers verbally, which is really quite a task. There are ofter mistakes in the number and you have to start all over.
Since Sony phones blow
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
I said in another thread that this did not work, but when I re-established the link with my Blackberry it worked fine.
Now I will tell you the interface for this feature on the TL if weak, you need to go through a long set of menus every time to find a number and it does not use the phone numbers for caller ID for incoming calls or for NAVaddresses, but that being said, I now have the couple of hundred numbers loaded on.
So I will give it a C-
You can get a compatible SE phone on EBAY for $80.
Bluetooth and ipod questions
what is the procedure for connecting the phone to the PC and then sending it by Bluetooth to the car? I just took delivery of a 2007 TL Type S and there doesn't appear to be any phone that allow downloading of a phonebook.
The US model has a cable gor connection to the IPOD. The Canadian model (me)
has an input jack in the centre console. Is the cable needed the same?
In any case. I love the car. Too bad that it doesn't have a power steering wheel like the Maxima or the Infiniti. I chose the Acura over the G35X.
Rogers is the only provider I can find that offers Sony phones and the models they offer don't appear on the Acura mini site as supporting Phonebook Transfers.
I'm waiting for a software upgrade for my Motorolla Q that will enable the PBAP on my phone.
The Ipod cable you're referring to is the Acura MusicLink, a dealer installed option. Do a search for users experience before you lay our $500.00cnd for it. I think you're better off using the 1/8' jack in the center console.
The Motorola phones do not have the possibility to export contacts to the HFL. As far as I know only SonyErickson phones have that capability.
Apparently, some Motorola software exist that would activate that function on the Motorola phones. See the message received from Motorola after many enquiries:
"Thank you for contacting Motorola support, we appreciate your request and also we apologize for any inconvenience you may experience with your product.
Regarding your inquiry, in order to qualify the OBEX file transfer (Bluetooth profile that support the transfer of data between phone and other devices) on the phone, the unit it self have to be update to a new software version GATW_01.18.02
This new update for CDMA Razr is been release on the market a couple of weeks ago in United State, and maybe available in Canada at this moment, the main new feature of the update is to reset the restrictions of the device, over Bluetooth."
However, I have been unable to find out where I can get this software. One reply from Motorola was that the software was already available in Motorola Phone Tools. I downloaded this software but that only allows to transfer contacts from computer to phone.
If anyone knows where that software is available, I would appreciate it.
'17 RDX Tech AWD - WDP
There's one very important piece that seems to be missing in this thread.
Yes, the phone must support the OBEX access and transfer, but SO MUST THE PROVIDER. Verizon Wireless has pretty much disabled all of this kind of functionality on all of their phones. So, even if the PHONE supports it, VZW has turned the feature off.
Go TL it on the mountain!
![what](https://acurazine.com/forums/images/smilies/what.gif)
Originally Posted by Toronto-TL
Has anybody tried this to see if it works?
Originally Posted by BrandonClaps
To see how well it works?
to each his own.
Originally Posted by billycuth
okay. sure. check to see how well it works. then what? spend 5 minutes deleting everything? Maybe the hfl on the '07 has a reset to it, and it's easy, but on a test drive, that would seem cumbersome to me.
to each his own.![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
to each his own.
xsilverhawkx
09-28-2015 06:51 PM
rboller
09-23-2015 02:49 PM
