Do I have a blown stock amp fuse?
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
I installed a new amplifier in my trunk. The amp is wired and gets juice and turns on and off, like it is supposed to. However, I can't get sound to the speakers. I have a Rockford Fosgate 325.1 mono amp.
I connected an LOC to the wiring of the stock sub. Hopefully the wiring is correct. Maybe you can help. I have a LOC with 4 wires coming from it. One gray wire with a black stripe, one gray wire, one white wire with a black stripe and one white wire. The old sub had 2 wires, one yellow and I think the other blue.
Which wires go together?
Secondly, if it still does work, did I blow a fuse in the stock amp so it stops giving the signal to the wires that went to the stock sub? The reason I ask this is that I tried to connect up the old sub to see if it worked and it didn't seem to.
What am I missing?
I had it working for a while with an old amp, but that old amp finally died. I don't remember how I had the wires connected to the LOC. Do I need the new amp switched a certain way, HP, LP, AP crossover?
Help!!
What am I missing?
Help!!
I noticed that the center channel isn't working either. I can't get the nav directions for turns to come on. The only time I hear something is if I crank up the volume to the max and then I can barely hear the voice directions. HEEEEEELLLPPP
polish_pat
09-25-2015 12:24 PM
4drviper
09-23-2015 09:00 PM
