DIY Plexiglass neon design?
Old Mar 8, 2006 | 06:08 PM
05TLTony's Avatar
Dr. Feelgood
I've noticed that someone had an Acura symbol etched onto the plexiglass on their subwoofer box and was wondering if it could be a diy. Just wonder if it is possible to attempt by one's self. Thanks
Old Mar 9, 2006 | 06:02 PM
ITL's Avatar
ITL
I do my own work.
I'd like to know, too. The case for my carpc is plexi.
Old Mar 9, 2006 | 06:53 PM
BrandonClaps's Avatar
this is usually done with a sand plaster, but can also be done with sand paper. They mask the outline of what they do NOT want etched, and then spray it....You can do the same with sand paper, or they even make a spray paint type thing that gives the same effect.
Old Mar 10, 2006 | 06:52 AM
05TLTony's Avatar
Dr. Feelgood
Where does one obtain a spray paint type thing?
Old Mar 10, 2006 | 01:42 PM
Sears
Old Mar 10, 2006 | 02:18 PM
ITL's Avatar
ITL
I do my own work.
What is it? a sandblaster in an aerosol can?
Old Mar 10, 2006 | 04:21 PM
enormus's Avatar
Lt. Dangle
Etching
It chemically etches the plastic. I did it to one of my PC windows. Craft stores have it as well (A.C. Moore, Michael's, etc.).
Old Mar 10, 2006 | 05:44 PM
no its just paint, it can come off if u want it to...i haven't seen a chemical one
Old Mar 14, 2006 | 10:36 AM
tfe691's Avatar
You can also just get a frosted glass spray. Make a templete or use fine line automotive body shopt tape and make the design mask it off and spray it.
Also instead of a neon get like 1/2 - 3/4 inch plexi and drill 1-2 small holes per side of plexi and install led's. I will illuminate the fosted or etching and the edges of the plexi.
Old Mar 14, 2006 | 11:40 AM
05TLTony's Avatar
Dr. Feelgood
Thanks for the tip
Old Mar 14, 2006 | 01:21 PM
thats what i'm talking about
Old Mar 15, 2006 | 05:38 PM
tfe691's Avatar
Originally Posted by 05TLTony
Thanks for the tip
Anytime. Also on that idea next time you mount an amp mount it on plexi and put like 4 leds in the plexi under the amp. ie take a hole saw and drill a hole smack dab in the middle of the make notches or holes and install. The edges will look sick.
Old Mar 25, 2006 | 08:43 PM
JMLAudio's Avatar
Just one plexi example
Old Mar 25, 2006 | 11:14 PM
Toyangel's Avatar
823
Here's the link on mine... the plexi on mine is actually ingraved in the back.
https://acurazine.com/forums/ramblings-12/any-places-buy-diesel-stuff-130597/
Old Mar 27, 2006 | 07:28 AM
cM3go's Avatar
That looks sick! Nice setup!
Mike734
Dec 10, 2021 01:25 PM
tsx_boy
Dec 13, 2019 08:33 PM
gatrhumpy
19
Dec 31, 2015 04:22 PM
scionxb3003
Sep 22, 2015 05:28 PM
