Compustar Window roll up and down help
321 whp SAE
I just got a Compustar alarm/remote start installed. Does anybody know how to get control of the window roll up and down? thanks
321 whp SAE
i need 2 separate modules for the windows and sunroof? Shouldn't there be a way to control all windows as well as sunroof? considering the key can open and close all windows ? thanks for any help
Team Anthracite Member
The DEI 530T module will only control two windows. I wired up my alarm to control ALL windows and sunroof at the same time using the wires that get triggered when you do the double key turn in the keyhole on the driver's door. With the Compustar, you have to get PAC TR-7 timers and build a timer circuit that pulses and holds the wire for as long as it takes to fully open or close the windows/sunroof. With a DEI alarm, you need timers for close but not for open since you can press and hold a button on the remote.
I would recommend that you only do this project if you are quite tech-savvy, it involves opening the door panel and doing some fun stuff in there.
If you want more help, let me know, I've done a lot of electrical work on the car since I've already had two alarm/starters installed (Compustar which I had a lot of trouble with, and Viper 791XV which I am loving).
Rob
Rob
xsilverhawkx
09-28-2015 06:51 PM
