Compiling an Official List of Bluetooth Phones Compatible with HFL
Old Aug 31, 2005 | 03:02 PM
  #81
bigman606's Avatar
Under the device properties on the phone, do you have the HandsFreeLink marked Trusted as Yes so that it doesn't require authorization each time you use the connection?
Old Aug 31, 2005 | 03:42 PM
  #82
Dumont's Avatar
Team Anthracite Member
Originally Posted by dajacobs
I just got this phone from Verizon. It paired and was able to make calls. But when an incoming call came in it could only be answered on the handset. Also, no signal strength or battery on the display.
Is there some adjustment that needs to be made on the phone set up? Any suggestions would be appreciated. Thanks.
When I got it early august all it showed on the MID was that is was connected too, but the calls always could be answered (and originated) with the buttons on the steering wheel. The only thing I had to setup on the phone was bluetooth all the time so that it automatically pairs after the initial setup in the HFL in the car. Maybe something is wrong with your phone or the car? Try setting it up again.
The signal strength and battery only started showing up on the MID after the software upgrade which just came out (which mainly was to give the phone full MP3 playing capabilities with the external buttons). You have to take your phone to Verizon for the upgrade. It takes some time so most likely you'll have to drop it off and pick it up later.
Dumont
Old Sep 1, 2005 | 12:24 PM
  #83
palmultiacura's Avatar
get the new firmware....(V04) fixes all the bugs..as well as sending full info to the MID
Old Sep 8, 2005 | 09:21 PM
  #84
velocityworks's Avatar
5th Gear
Company/Model of the phone: Palm Treo 650
Firmware Version: 01.31
Software Version: 1.15-CNG
Is this phone an OEM version or a provider customized version? Cingular (unlocked)
Does your phone automatically pair?: Yes
What shows up on the MID: Signal strength always "0"; Battery charge does not show up.; phone icon in top display does show up; Caller ID does work.
Service Provider: Cingular
Geographical Location: Georgia
What is your RF/signal strength like? Full signal on phone.
All pairing, transfer, caller ID and call waiting functions work perfectly with the new firmware update.
Old Sep 22, 2005 | 08:41 PM
  #85
Red05TL's Avatar
Motorola A1000
Company/Model of the phone: Motorola A1000
Firmware Version: 51.92.08
OEM/Generic with FW 51.92.08
What shows up on the MID: No Signal, no battery,
Geographical Location: Miami, FL
Signal strength is very good in all location.
Old Sep 23, 2005 | 12:49 PM
  #86
cullal's Avatar
Company/Model of the phone: Palm Treo 650 (Unlocked GSM)
Firmware Version: 01.28
Software Version: TREO650-1.13-ROW
Is this phone an OEM version or a provider customized version? Unlocked GSM
What shows up on the MID: Signal Strength - NO, Battery level - NO, Caller ID - NO
Geographical Location: Pittsburgh, PA
Old Oct 30, 2005 | 09:43 PM
  #87
ibnabouna's Avatar
Sprint PPC-6700 (HTC Apache) Works
Hello,
I can confirm that the new Sprint PPC-6700 PDA phone, which runs Windows Mobile 5.0, works fine with at least my 2005 Acura TL w/ nav.
So far, the Bluetooth connection has dropped only once. Also, I've had to press the "End Call" button on the steering wheel a couple of times to end a few stubbornly connected calls. Finally, the car does not show any signal or battery strength information with this phone, but caller ID shows up fine.
Otherwise, all is well.
-Paul
Old Oct 30, 2005 | 09:55 PM
  #88
peterpan_991's Avatar
For Verizon
http://dts.vzw.com/how_to_use/bluetooth_car_kit.html
Old Nov 6, 2005 | 08:32 AM
  #89
apatent's Avatar
Samsung MM-A940
anybody try this new Sprint phone with their TL?
Old Nov 16, 2005 | 10:22 AM
  #90
sangwl's Avatar
also curious................
sang
Old Nov 17, 2005 | 04:24 PM
  #91
Zeb's Avatar
Zeb
TMobile - V600.
Phone : Motorola V600
Service Provider : TMobile
S/W Version : TRIPLETS_G_0B.09.3AR_A
Flex Version : GS9V600TMB02NA157
Am the new owner of a 05 TL. Love the car so far. Initially had a problem pairing the phone. Called Acura, they told me that this phone was on the incompatible list of phones. After reading through various articles about Flashing the firmware, etc... I decided what the heck I should give it another try. This time I tried to connect to the Bluetooth from the phone rather than the car try it, and I didn't have any problems in doing so. Right now, the display has the phone icon and the battery strength indicator. I also get the caller id displayed on the center console.
Lu this forum, keep it going guys.
zeb.
Old Nov 26, 2005 | 10:11 AM
  #92
HiTEC's Avatar
Firmware Version: v1.12a
Is this phone an OEM version or a provider customized version? Customized Sprint
What shows up on the MID: Phone and Signal Strength
Service Provider: Sprint
Geographical Location: Aurora, Illinois
What is your RF/signal strength like: Good 3 to 4 pbars show on MID
reception like MOST of the time: Great, I have no problems in the Chicago are
According to Acura's web site this only Treo they support is the Sprint version with the 1.12 version of firmware. Says it supports all items except car diags and battery meter.
I know there was just a Cingular firmware update that came out 2 days ago. I wonder if this added more BT compatibility like the last Sprint update did.
Old Nov 26, 2005 | 10:13 AM
  #93
HiTEC's Avatar
I don't know if this helps, but on the Acura Hands-free Link web site, under Sprint they specifically list the 940 as NOT compatible. I have not been hearing good things about the bluetooth on this phone on the Sprint forums.
Old Nov 26, 2005 | 10:45 AM
  #94
bluengu's Avatar
Company/Model of the phone: HTC Wizard (aka Imate KJam)
Firmware Version: 01.2.10.2
Software Version: Unknown
Is this phone an OEM version or a provider customized version? T-Mobile
Service Provider: T-Mobile
Geographical Location: Wichita, KS
What is your RF/signal strength like? Moderate
Old Nov 26, 2005 | 11:54 AM
  #95
emuyshondt's Avatar
Firmware Version: 1.51 Firmware / 1.17 Software (CNB)
Is this phone an OEM version or a provider customized version? Cinguler Blue (formerly AT&T), Unlocked
What shows up on the MID: Phone presence, Signal Strength, the letters RM (?)
Geographical Location: Austin, TX
What is your RF/signal strength like? 3-4 bars
What is the reception like MOST of the time? Mostly good, but there are a few areas that are bad: Tumbleweed Hill, near Davenport Ranch on 360, some parts of RR620.
Old Nov 27, 2005 | 11:54 PM
  #96
cullama213's Avatar
Question Nokia 6682, DOES IT WORK?
Guys,
I am new to this forum, but am getting ready to buy a TL and have a question... does anyone know if the nokia 6682 works with the handsfree??? It is listed as not working on the acura website, but so is the sony s710a... but someone on this forum said they got the s710a to work... so i was wondering if the nokia is in the same book or if there is a way to get it to work... please let me know...
Old Nov 28, 2005 | 04:34 PM
  #97
kuj's Avatar
kuj
6682 works. Doesn't show the battery or signal bars though.
Info for the 6682:
Company/Model of the phone: Nokia 6682
Firmware Version: 3.01.1
Is this phone an OEM version or a provider customized version? Provider
What shows up on the MID: Phone, Antenna (no bars though), CallerID
Geographical Location: San Francisco, CA (Bay Area)
What is your RF/signal strength like? 4-5 bars
What is the reception like MOST of the time? Very good.
Info for Sony Ericsson Z520a:
Company/Model of the phone: Sony Ericsson Z520a
Firmware Version: R3C042
What shows up on the MID: Phone, Battery, Antenna (w/ bars), CallerID
Info for Nokia 6230b:
Company/Model of the phone: Nokia 6230b
Firmware Version: 5.35
Is this phone an OEM version or a provider customized version? Provider but decustomized/flashed through 3rd party
Old Dec 3, 2005 | 10:47 PM
  #98
robhoff's Avatar
Angry A940 Incompatible with '04 TL
I purchase a Sprint (Samsung) A940. It appeared to work sometimes with my TL but on two occasions my handsfreelink froze on "incoming ca;;" and I had to disconnect the battery to reset my handsfreelink.
I previously had a Sony 608 with no problems other than some calls would switch to the phone after dialing.
Old Dec 8, 2005 | 05:20 PM
  #99
denm316a's Avatar
Motorola RAZR V3c
Company/Model of the phone: Motorola RAZR V3c
Firmware Version: GATW_01.0F.02
Service Provider: Verizon Wireless
Geographical Location: Philadelphia, PA
Old Dec 9, 2005 | 06:58 AM
  #100
salgiaco's Avatar
Umpire #27
Thanks for the info - we've all been waiting. How did you get one so fast? I thought they were just released yesterday or the day before via internet only?
Old Dec 10, 2005 | 06:57 PM
  #101
Filip75's Avatar
SSgt, USAF
I've picked my RAZR V3c up today. And not from Internet, but from a store. $99 after mail-in rebate. Not bad, eh?
Old Dec 11, 2005 | 06:04 AM
  #102
crwmlw's Avatar
Help with RAZRV3c Verizon and 06 tl
Hi hopefully someone can help, I have an 06 TL that we just purchased along with a new Verizon RAZR V3c. I paired the phone and it recognized it, the only problem is now if I have the phone on and get in the car and start up it doesnt sync with the phone, I have to go in the phone settings and look for devices then it will work, but after I leave the car and go in it again I have to do that over and over. Any ideas please?
Old Dec 11, 2005 | 03:25 PM
  #103
denm316a's Avatar
I am unsure of your issue, mine pairs each time I get it. Just a thought, check to make sure that you have bluetooth powered on at all times.
Old Dec 11, 2005 | 05:14 PM
  #104
QuickRick's Avatar
bluetooth
I want a Motorola Razr phone but my Verizon dealer is making it expensive. I like our Verizon service but their Razor is more expensive that all of the competition for purchase. Their "deal" is $299 less $100 = $199.00 for this phone. T-Mobile and Cingular offer the same phone for $50-$100. Does anyone have this Razr phone and how do you like it while I wait out this stupid pricing of theirs? QR
Old Dec 12, 2005 | 08:48 AM
  #105
sangwl's Avatar
what is this website?
just curious
sang
Old Dec 12, 2005 | 09:00 AM
  #106
drdamian's Avatar
FOR SALE - BM
I have the razr also in my car. works flawlessly. but, everytime i get into the car i need to turn the bluetooth of the phone on. it dosnt' just sync up. what i did was set one of my hotkeys as a bluetooth button. its a little easier than going through the menu option
Old Dec 12, 2005 | 04:57 PM
  #107
muadib's Avatar
Yes, but the phone is new to Verizon, which is why it is more. You could find it cheaper online, but the deals are almost always for new subs only.
Old Dec 21, 2005 | 09:25 AM
  #108
rlsalmon's Avatar
3rd Gear
Bluetooth Treo
Company/Model of the phone: Cingular Treo 650
Software Version: Treo650-1.15-CNG
Is this phone an OEM version or a provider customized version? Provider customized
Does your phone automatically pair?: Not sure what you mean here - I had to go through the pairing process once, since then it connects automatically.
What shows up on the MID: Nothing (One bar where the battery indicator s/b but no battery strength bars
Geographical Location: Temple, TX
What is your RF/signal strength like? Don't have the signal indicator, but I can tell I have a pretty good connection. Rarely drop calls, rarely lose voice, HOWEVER, occasionally making a phone call will cause my Treo to reboot. (1 in 12)
Old Jan 4, 2006 | 09:33 AM
  #109
Brewmaster's Avatar
I'm Baaack!
Sony Ericsson w600i
Company/Model of the phone: Cingular SonyEricsson w600i
Software Version: no clue
Is this phone an OEM version or a provider customized version? OEM
Does your phone automatically pair?: Yes, and phone sounds confirmation tone which is a nice feature.
What shows up on the MID: Signal strength and battery meter
Geographical Location: Delaware
What is your RF/signal strength like? RF signal is tremendous. My SE T637 had good signal (much better than my wife's motorola), this one is even better. It also has edge so downloads are extremely quick.
Old Jan 4, 2006 | 05:10 PM
  #110
ashamooilian's Avatar
Question Samsung I 730
Does anyone know if the Verizon Samsung I730 works with the Acura TL??
Old Jan 5, 2006 | 10:36 PM
  #111
eimea's Avatar
9th Gear
i730
ashamooilian,
Yes, the i730 does pair, but with out the capability of answering call waiting, and I believe without signal strength or battery strength, or both.. not for sure. My husband has the i730, but he rarely drives my car.
Old Jan 9, 2006 | 10:54 PM
  #112
rmastbro's Avatar
i-mate SP5
Company/Model of the phone: i-mate SP5
Firmware Version: 1.0.8.0 - Windows Mobile 5.0
Geographical Location: Orlando, FL
Old Jan 12, 2006 | 03:07 PM
  #113
JinVA's Avatar
8th Gear
Thumbs up Blackberry 7250
Company/Model of the phone: Blackberry 7250
Is this phone an OEM version or a provider customized version? assume Verizon customized
Firmware: unsure (4.0.0.6 maybe)
Does your phone automatically pair?: Sort of (see below)
What shows up on the MID: Battery, Signal Strength, Caller ID
Geographical Location: DC Metro
What is your RF/signal strength like? full bars
What is the reception like MOST of the time? Excellent
The Blackberry prompts to make the connection (Yes or No) w/ HFL each time I get in the car. Trying to find out if I can make it fully automatic. However, I may keep it the way it is in order to have the option to keep the conversation private. BTW, the 7250 is on the approved phones list on the Acura & Verizon websites, so the fact that it works isn't really a surprise. I just got the phone & wanted to be sure of compatibility.
Old Jan 13, 2006 | 12:42 PM
  #114
ludachrisvt's Avatar
Wants an M3 in
does anyone know if the treo 700w is compatible?
Old Jan 18, 2006 | 12:03 PM
  #115
AAP's Avatar
AAP
Company/Model of the phone: Nokia 8801
Firmware Version: 3.76
What shows up on the MID: Called ID Only
Geographical Location: Cleveland OH
What is your RF/signal strength like? Depend on where I am
Old Jan 18, 2006 | 03:37 PM
  #116
Subhuman's Avatar
Company/Model of the phone:Motorola E815
Firmware Version:8720_01.17.03
Is this phone an OEM version or a provider customized version?assuming Verizon did
What shows up on the MID: Phone, Signal Battery, Yes to all
Geographical Location: Tacoma,Wa.
What is your RF/signal strength like?usually full bars,3 I believe on phone and in car as well.Around the greater Puget Sound area I've had no signal problems at all.Never low.
Old Jan 19, 2006 | 01:41 AM
  #117
jstreet's Avatar
Originally Posted by eimea
ashamooilian,
Rumor has it that there exists some patch that would make the Samsung A900 phone work in Hands Free mode on a 2005 RL. Does anyone know about it?
Old Apr 30, 2006 | 08:41 PM
  #118
tzakiel's Avatar
Cold Racketeer
Sony Ericsson phones such as w900, k750, and w810 do not seem to be working properly with HFL after the latest firmware updates... I hope this can be fixed, a lot of people do have these phones.
Old May 2, 2006 | 11:56 PM
  #119
landshark99's Avatar
Nokia 7610
Company/Model of the phone: Nokia 7610
Firmware Version: unknown
Is this phone an OEM version or a provider customized version? Vodaphone UK, using T-Mobile chip
What shows up on the MID: Phone Icon
Geographical Location: Gainesville, Florida
What is your RF/signal strength like? 2 or more bars, phone is usually below radio
Old Jun 23, 2006 | 12:40 PM
  #120
-sNaFu*'s Avatar
All the world's a stage
Anyone know if the Nokia 6102i from Cingular works with our TL's. I have a 2006. Also, to whomever has this phone, how do you like it?!?
