Clock panel is flickering
Old Mar 6, 2018 | 02:30 PM
kliqzero's Avatar
the panel in my 2005 Acura TL that shows the clock and volume for music, ect flickers and sometimes goes completely dim. I have to hit the panel for it to come back, and even then its only temporary. Is this a fuse issue?
Old Mar 10, 2018 | 01:33 PM
Efu2d's Avatar
4th Gear
My 2006 RL has the same issue.
Old Mar 11, 2018 | 10:17 AM
SpiderX1016's Avatar
Usually a display issue. Needs to be replaced or if possible, repaired.
Old Mar 11, 2018 | 01:54 PM
guitarplayer16's Avatar
After I replaced my clock panel the issue stopped occurring.
Although some people claim it's a loose connection at the wire harness connector, I'm certain it's an internal problem which you can't fix unless you know how to solder.
Old Apr 3, 2018 | 06:41 PM
Openail Francois's Avatar
8th Gear
all you gotta go it stick something underneath the connector to snug it up.
Old Apr 3, 2018 | 10:16 PM
Levon05TL's Avatar
def not a connector issue. It’s how the soldering hold up together across the whole screen module
Old Apr 3, 2018 | 10:23 PM
8th Gear
Not sure what I did, but the brightness kept flicking on and off until a couple of good whacks then stayed on. Then I just stuck something in between the connector and BAM! Never turned off again. That's just my method tho
kliqzero
Mar 6, 2018 02:52 PM
