Clock adjustment on Navi TL's
Greetings:
After having my TL jumped this morning the clock in the upper display is wrong. I checked the clock for the Navi and it is correct.
There is suppose to be some method to adjust the clock through the radio but my '04 TL does not have a "h" or "m" indication on or near the present buttons.
If any one can help me I'd appreciate it.
the one on the top display is connected to the navi, so you might have redo the navi time again. Is on page 4 of the setup.
No luck. The time in the upper display stayed the same.
Previous Owner
try going thru the navi setup or something
Map/Guide + Menu + Cancel button all at the same time and hold it until you see a different menu.
You may have to reload the disc or something. if all else fails, take it to the dealer.
Registered but harmless
Received 1,112 Likes
Originally Posted by Precision Crafted
Nope.
If not, prior posters' advice is good- screen 4 on set-up menu for the Nav system has the clock adjustment.
My Daily Driver
1 Post
^^ Yup. I noticed this when driving from WI to CO as well. The time on the navi/clock is a little bit behind. It will take a bit for it to catch up. Just give it till tomorrow at the latest, if it is still not matched, try disconnecting the battery or just take it to the dealership and let them deal with it.
Originally Posted by Klutch
loll....i havent even noticed a clock on my navi
lanechanger
10-13-2015 10:56 AM
