Clock Adj.
Old Mar 12, 2007 | 12:04 AM
jordanboyko's Avatar
04 Double Door
Clock Adj.
does anyone know how to change the clock in the 04 tl?
Old Mar 12, 2007 | 01:50 AM
ILLustriousUA6's Avatar
Feenin on some 20's
setup, #4 I think
Old Mar 14, 2007 | 03:31 AM
swtboi131's Avatar
AcuraTL2004
I thought it suppose to automatic do it by itself with the GPS. If i remember that right.
Old Mar 14, 2007 | 07:56 AM
lusid's Avatar
FTW
It's "suppose to" change automatically, but since bush changed the day light savings date, the car / gps doesnt know to change it. There was a tsb about it though.
Old Mar 15, 2007 | 03:43 AM
swtboi131's Avatar
AcuraTL2004
Yea it should change sometimes this week
or by march 21 when springs really begins
Old Mar 15, 2007 | 12:24 PM
04 Double Door
yah setup 4 is the way thanks a bunch.... u can change time, auto daylight savings, auto time zone changing......i live between time zones so i always wondered if u can change it. thanks again tlboi.
Old Mar 16, 2007 | 05:26 AM
swtboi131's Avatar
AcuraTL2004
DO you have NAV or NO nav because both is different when it comes to changing time.
Old Mar 16, 2007 | 09:17 AM
1995hoo's Avatar
Keep Right Except to Pass
It would change on April 1, which is when Daylight Saving Time would have begun under the 1986 amendment to the time zone law (first Sunday in April, changed from the pre-1986 last Sunday in April).
Old Mar 16, 2007 | 09:54 AM
HiTEC's Avatar
All this DST stuff has been beaten to death in multiple other threads prior to the DST change last week.
Old Mar 16, 2007 | 09:59 AM
lusid's Avatar
FTW
true, but the question was "how do you change the clock" not why hasn't the time automatically changed.
But it got kinda derailed.
Old Mar 16, 2007 | 10:57 AM
HiTEC's Avatar
Understand... if the op wants an answer to his question he either needs to tell us if he has Navi or not or he can simply open his owners manual and look in the table of contents and he should be able to find his answer.
Old Mar 16, 2007 | 12:04 PM
datmrman's Avatar
Then lets stay on the clock adjustment topic so I don't have to lock this thread as being a repost to DST.
Old Mar 20, 2007 | 07:44 PM
TL-Rocket's Avatar
I have an '04 TL with NAVI and the manual says that the clock will change automatically. There the instructions end.
Does anyone know of a way to change the clock on a TL with NAVI? I have a very time sensitive job and its becoming confusing at times to make the mental adjustment.
Thank you,
TL-Rocket
Old Mar 20, 2007 | 07:58 PM
lusid's Avatar
FTW
Did you read the thread out of curiosity?
Old Mar 20, 2007 | 08:04 PM
TL-Rocket's Avatar
Yep, I read the thread....
Only thing I can glean is something about option #4...
I read the owners manual and there's basically nothing you can do but wait for the NAVI to catch up - or do you know more?
Thank you,
TL-Rocket
Old Mar 20, 2007 | 08:16 PM
lusid's Avatar
FTW
Okay, as far as I know on my 2006 model, all i do is go to Setup, hit the number 4, and the clock setting is located there.
Old Mar 20, 2007 | 08:43 PM
TL-Rocket's Avatar
I have an '04. I went through the list and I saw no entry for a clock adjustment, but I'll check again tomorrow. Did the '06 owners manual say anything about adjusting the clock for a NAVI model?
Thank you,
TL-Rocket
Old Mar 20, 2007 | 10:45 PM
Will Y.'s Avatar
Registered but harmless
Thank you,
TL-Rocket
IIRC, on setup screen 4, there will be touch-rectangles for Time Zone and "Auto" on top and towards the bottom of the screen are big "+" and "-" symbol touch-rectangles next to rectangles for hour and minutes.
Touch the rectangles to adjust the time.
Old Mar 20, 2007 | 11:00 PM
datmrman's Avatar
You are correct. The Owners manual states that models with navigation will update the clock automatically.
You will have to look at the Navigation manual. In there you will find this:
Set-up Screen 4
Say or select Set-up Screen 4 and the following screen appears:
Time Zone/Clock
Allows you to set Daylight Savings, Auto Time Zone, and Time Adjustment. The factory setting is On.
Auto Daylight Savings Time
Sets automatic daylight savings time On or Off. If you reside in a state where daylight savings time is not used, then you may want to turn this feature off.
NOTE: If you set Auto Daylight Savings Time to On, the Daylight Savings Time function is activated even in an area that does not adopt the Daylight Savings Time system.
Auto Time Zone by GPS
Sets automatic time zone selection by GPS On or Off. If you are driving across the country and passing through time zones, this feature will automatically set the time to the time zone you are traveling through. However, if you live and work in two different time zones, you may want to turn this feature off.
NOTE: If you set Auto Time Zone by GPS to On, correct operation may not be obtained in some areas near a time zone boundary.
Time Adjustment
Adjusts the current time in hours and minutes. You can reset the adjustment by selecting Reset. Selecting Return lets you return to the Set-up screen.
NOTE: Even though the time is shown in the upper display as a 12-hour clock, you need to adjust it as a 24-hour clock. For example, if you want to set the time in the upper display to 7:00 p.m., you need to adjust the time to 19:00. Remember to add 12 for any time from 1:00 p.m. to 12:00 a.m.
BTW, the manuals are available online here: https://techinfo.honda.com/rjanisis/...01_OMANUAL.ASP
Old Mar 21, 2007 | 03:24 AM
swtboi131's Avatar
AcuraTL2004
I have the same year and model.. just wait till april man.
Old Mar 21, 2007 | 08:08 AM
1995hoo's Avatar
Sorry if I sound snippy, but I don't see why this is apparently so damn hard for people to understand:
(a) The manual does say the clock will adjust automatically. For 2004 and 2005 TLs, however, the manual was written and printed before Congress changed the dates for Daylight Saving Time, so the issue is not addressed because it was an unexpected change in the law. The clock will still adjust itself, but it will do so on the wrong dates per the 1986 version of the DST schedule. (I bet many of you don't remember that DST used to start on the LAST Sunday of April prior to 1986.)
(b) I don't know what the manual for the 2006 or 2007 TL says, but I assume it's the same because we know Acura and Alpine did not create a software patch to change the dates.
(c) You can change your clock manually by going to the "Setup" screen, selecting screen 4, and selecting the option to adjust the clock. You will need to set the "Auto Daylight Saving Time" option to "Off." Then use the + and - buttons to adjust the hour to the correct time.
(d) On the first Sunday of November (this year, November 4), you will need to go into Setup screen 4 again to set your clock back one hour because Congress extended the end of Daylight Saving Time by one week.
(e) If you adjust your clock but do not turn off the Auto DST option, your clock will advance by one hour on the first Sunday of April (this year, April 1) and your clock will be an hour fast because you already adjusted it. The computer doesn't know that the DST dates changed.
(f) If you're too lazy to change it yourself, or if these very simple steps are too confusing, then you can ignore it and your clock will advance by one hour on April 1. You will need to be cautious in the meantime, however, to be certain that you remember that your car's clock is one hour slow in case you rely on it when you are going somewhere. Likewise, in the fall your clock would drop back on October 28, a week early.
All of this is, of course, for Navi-equipped TLs only. I have no idea how to set the clock in a non-Navi TL.
(BTW, to nit-pick, there is no such thing as "Daylight Savings Time." It's "Daylight Saving Time.")
Old Mar 21, 2007 | 12:07 PM
datmrman's Avatar
Non-Navi TL have an H and M button and have no automatic time adjustment feature.
On Models without Navigation
The clock displays the time with the ignition switch in the ON (II) position. If your vehicle’s battery is disconnected or goes dead, you will need to reset the clock.
Change the hour by pressing and holding the H button until the numbers advance to the desired time. Change the minutes by pressing and holding the M button until the numbers advance to the desired time.
You can quickly set the time to the nearest hour. If the displayed time is before the half hour, press the R button to set the clock back to the previous hour. If the displayed time is after the half hour, the clock sets forward to the beginning of the next hour.
For example: 1:06 will reset to 1:00
1:52 will reset to 2:00
Old Nov 17, 2007 | 03:05 PM
gynuine69's Avatar
Question
Hate to revive an old thread but this has been driving me crazy. I dont have an issue with DST, but more so with my top dash time being wrong all together. I have an 05 TL w/nav and Ive tried this option however in the setup screen it shows the correct time but STILL does not change the clock in the small top dash screen. Any one know what the heck could be the problem? Any work arounds or maybe I have a faulty carputer?! Thanks for the quick responses!
Old Nov 17, 2007 | 03:22 PM
Will Y.'s Avatar
Once the time is adjusted in setup, try pushing "enter" instead of "reset" to see if that corrects the display problem.
Old Nov 18, 2007 | 12:17 PM
gynuine69's Avatar
the only option given is "return" no enter.... im it in to the dealership for them to take a look. Other posts ive seen regarding this issue gives me the impression that there might be something wrong with the navi unit. so lame....
Old Dec 4, 2007 | 09:18 AM
Slvr04TL's Avatar
I have the same problem. The dash clock is wrong, but the Navi clock is correct. I noticed this when I changed my battery
gynuine69 - Did you ever resolve the problem?
Skirmich
Oct 1, 2015 12:59 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
2Quik
Sep 23, 2015 01:03 PM
95legend6speed
Sep 21, 2015 06:40 PM
