Clicking sound from right speaker 2006 Acura TL
Old Jul 17, 2022 | 05:01 PM
r2r4r7's Avatar
3rd Gear
Clicking sound from right door speaker and right tweeter. Changes pitch when I rev the engine. Its intermittent, often times it either goes away or starts when I make a turn. Very annoying. It happens even when I'm not listening to anything on my stereo. Any help would be appreciated. My current solution is unplugging the speakers, which isn't ideal. I don't think its related but I did replace my stock radio with a double din from pioneer a few months ago. Link is to a yt video of the sound.
Old Jul 19, 2022 | 12:01 PM
Jackass's Avatar
Did you bypass the factory amp? What was the goal of replacing the factory HU with aftermarket?
The fact that the tone changes with engine speed leads to a power issue most likely. If the factory amp is still in the picture, could be a ground loop, or the factory amp needs to be rebuilt. If the factory amp was removed and only the aftermarket HU is in the picture, it is most likely a ground issue.
Old Jul 19, 2022 | 12:30 PM
r2r4r7's Avatar
3rd Gear
Factory amp is still in use, I replaced the head unit so I could play my own music and not just listen to the radio. I used a pioneer DMH1700NEX, and apparently pioneer has had issues in the past with the pico fuses grounding the RCAs popping and causing the exact interference I'm getting.
So I think I'm gonna replace the factory amplifier with an aftermarket which I was going to do anyways, and if that doesn't work I'll replace the head unit. I already contacted the seller I bought it from and they said they would send me a new one. I would swap the left and right rca channels to confirm it's an issue with the deck, but it's a pain to take apart the center console just to check the RCAs.
Appreciate the advice, I'll post what the issue was once I fix it.
Old Jul 19, 2022 | 02:33 PM
Ratm68's Avatar
i had the same problem when directly wiring aftermarket signal to factory amp. my audio became extra loud and and low/no volume, it buzzed. aftermarket headunit is already preamp and can drive speakers directly, w/o the oem amp. Very easy solution w/o going into the dash. simply get to the amp in passenger kick panel, find the corresponding input/output speakers wire and connect. I only kept the oem amp to drive the oem sub.
Old Jul 25, 2022 | 10:35 AM
r2r4r7's Avatar
3rd Gear
Update:
Issue was the Pioneer deck itself. I replaced the factory amp and it just made the clicking louder, which was comical. After some digging I found out that Pioneers are known for having the pico fuses that ground the RCAs blow out. So I took the deck out, tied a 22 gauge copper wire around the RCA pigtails and wrapped each one in electrical tape, then terminated the wire at one of the screws on the deck. A ghetto solution for sure, but it worked great.
Old Oct 31, 2022 | 03:40 PM
jonz2004tl's Avatar
Smile 2004 TL buzzing in all speakers of audio system
i had the buzz in all speakers with volume at 01 and engine on. noise went away when i turned engine off. removed the amplifier and sent it to a guy that repairs them on eBay:
2004 - 2008 Acura TL Amplifier Audio REPAIR SERVICE $134.10 plus shipping
Fix for buzzing, static, low or no volumegreat communication, fast turn around. I reinstalled the amp in 30 minutes and my radio sounds great again.
Old Nov 10, 2022 | 02:17 PM
Chad05TL's Avatar
I think it is the Factory Amp going bad.. I have had 2 OEM amps.. Both Did that noise. And now the AMP barely makes any sound. I crank it all the way and it barely works.
And the Colder it is outside, the Worse it is.. (Quieter, less amplification)
I will go aftermarket and try to find a wiring Adapter somewhere.. Maybe sonic has one? no idea!
WunderWagen
3G RDX (2019+)
Mar 9, 2022 12:22 PM
AZBlackTL
Jun 7, 2009 11:01 PM
wong05tsx
Nov 24, 2007 10:06 PM
patient77
Jan 18, 2007 11:32 AM
exxtractor
1G TSX Problems & Fixes
Jun 20, 2006 03:13 PM
