cleansweep and sub?
Old Mar 27, 2006 | 11:01 AM
cliff's Avatar
Team NightHawk VP
cleansweep and sub?
i installed my cleansweep recently and everything works.
i do have an aftermarket sub tapped into the factory amp with a hi-lo convert.
meaning it will only work when im listening to a cd thru the OEM HU.
where would i tap it into if i want it to work with the AUX on the CS?
as of now there is no sub when i listen to my ipod off the aux on the cs.
Old Mar 27, 2006 | 02:13 PM
tfe691's Avatar
You can't you would have to loose one of your full range inputs (front or rear) or if you high's amp has a signal output take it to the sub amp input. If you want to do everything in one. Try getting the RockfordFosgate 360.1 It Will accept front, rear, and sub input and is all controlled through a palm os w/bluetooth.
Old Mar 27, 2006 | 04:20 PM
cliff's Avatar
Team NightHawk VP
damn...i was hoping for an easier way than to get a new audio controller device
although thats pretty neat how u can control the speakers via bt
Old Mar 27, 2006 | 09:30 PM
kyle-wdp's Avatar
2005 WDP TL
why didn't you run the sub amp through the cleansweep?
Old Mar 27, 2006 | 11:15 PM
cliff's Avatar
Team NightHawk VP
theres no input for sub on the cleansweep. its only 4 ch. for the 4 speakers.
Old Mar 28, 2006 | 01:47 AM
kyle-wdp's Avatar
2005 WDP TL
I know, it just seems that bypassing the cleansweep would defeat the purpose of owning one seeing as it isn't correcting any equilization if you don't use it.
Old Mar 28, 2006 | 08:02 AM
tfe691's Avatar
The rockford does the same but is more advanced and so is the alpine coming out this month and the one in august.
kstanton512
May 17, 2011 02:37 PM
msmith
76
Feb 2, 2011 04:37 PM
l7h8626
Jul 2, 2008 09:31 AM
SoundOff
Feb 4, 2006 10:56 PM
