Cingular Blackjack - Placing calls question
Old Jun 25, 2007 | 08:22 PM
packetjunkie's Avatar
I've been looking around and can't find any info on making a call with my Blackjack - I see that outgoing calls don't come up on the HF, but once I've placed the call is there a way to transfer it to the HF setup? Or am I stuck using the phone for any outgoing call which I don't use the voice dial feature for (like when I am checking my call history and want to call a number back)?
Old Jun 25, 2007 | 08:30 PM
bluenoise's Avatar
2004 SSM/EB/5AT/Navi/RSB
You can dial from the BlackJack and then say, "Transfer" to put the call on the HFL after the call has connected.
Old Jun 25, 2007 | 08:32 PM
Perfect, I'll give that a shot. Thank you.
Old Jun 25, 2007 | 11:13 PM
djyesh01's Avatar
but what about the incoming??? once you pick up the incoming from the HFL, u can't hear anything in the car and then you u have to disable the bluetooth from the phone in order to talk... why does it do that???
Old Jun 26, 2007 | 01:05 PM
bluenoise's Avatar
Mine takes incoming calls just fine. It rings, I hit the HFL button on the steering wheel, and I say, "Hello?" after I hear the call connect (which can take a few seconds).
Are you saying you answer a call but don't hear anything? Maybe the volume is turned all the way down on your HFL.
Old Apr 22, 2009 | 04:24 PM
vqt1988's Avatar
Hi I'm new to the forums and this is one big concern I have been trying to figure out too.
I have this same problem with my Samsung Blackjack 2. I can't use the HFL when I make outgoing calls, but all incoming calls work great.
Do I have set anything up in my phone or in the HFL in order for it to connect for outgoing/making calls? (05 TL with Navi)
tman570
Jun 11, 2019 07:56 AM
Skirmich
Sep 15, 2015 06:41 PM
datadr
Sep 12, 2015 09:12 PM
IndycarFaster
Sep 11, 2015 02:52 PM
