Cingular Blackjack - Placing calls question
I've been looking around and can't find any info on making a call with my Blackjack - I see that outgoing calls don't come up on the HF, but once I've placed the call is there a way to transfer it to the HF setup? Or am I stuck using the phone for any outgoing call which I don't use the voice dial feature for (like when I am checking my call history and want to call a number back)?
but what about the incoming??? once you pick up the incoming from the HFL, u can't hear anything in the car and then you u have to disable the bluetooth from the phone in order to talk... why does it do that???
2004 SSM/EB/5AT/Navi/RSB
Mine takes incoming calls just fine. It rings, I hit the HFL button on the steering wheel, and I say, "Hello?" after I hear the call connect (which can take a few seconds).
Are you saying you answer a call but don't hear anything? Maybe the volume is turned all the way down on your HFL.
Hi I'm new to the forums and this is one big concern I have been trying to figure out too.
I have this same problem with my Samsung Blackjack 2. I can't use the HFL when I make outgoing calls, but all incoming calls work great.
Do I have set anything up in my phone or in the HFL in order for it to connect for outgoing/making calls? (05 TL with Navi)
tman570
06-11-2019 07:56 AM
Skirmich
09-15-2015 06:41 PM
IndycarFaster
09-11-2015 02:52 PM
cak165
1G TSX Problems & Fixes
09-02-2015 09:21 AM
