Center Channel
Old May 24, 2008 | 02:16 PM
Len_A's Avatar
Center Channel
I've got the stock head unit running through a 3sixty. I noticed that when playing normal CDs (not surround sound) I can only turn off the center channel speaker via the 3 sixty - turning it off via the head unit controls doesn't stop the sound. Anyone else have this issue? I'm wondering if the install place screwed up the connections somehow.
Old May 24, 2008 | 04:26 PM
csmeance's Avatar
probably the installers did not connect up the center speaker connection to the 3.sixty and the 3.sixty is using the left and right to create an artifcial one. The 04-06 TL only uses the center for the HFL, Navi and for the center channel in DVD-A, otherwise it is off.
Old May 28, 2008 | 11:51 AM
Len_A's Avatar
I re-setup the 3sixty and now all's well. Looks like the install place messed up the setup (probably SUM'd the channels).
Old May 28, 2008 | 03:16 PM
CBR2200's Avatar
2008 KBP Type S
So in my 08 can I install a 3.sixty and amp but just leave the center channel setup as is? I have no plans to listen to any DVD-A's. The surround sound music sounds artificially surroundy to me. Live music comes from the stage, they don't play each instrument in a different corner of the room. As I understand it the center channel is unused for non-DVD-A or nav sources, is that right?
Old May 28, 2008 | 06:05 PM
Len_A's Avatar
Actually, some sound comes out of the center channel when playing normal CDs. It's probably just the sum of the front two.
Old May 28, 2008 | 09:12 PM
csmeance's Avatar
The center hosts the higher sounds, and a bit of the mids (voices), the left and right fronts give out the mids, and the rears act like filler tweeters.
vpasla1
Sep 17, 2016 07:24 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
