CDs won't play
Old Feb 14, 2006 | 12:47 PM
Superskate's Avatar
5th Gear
CDs won't play
I have recorded cd's from my playlist on my computer but they won't play in my 2005 TL. When I insert the disc I am given a message that the disk has to be formatted. I thought the CD-R discs were already formatted. Please Help!!!!! Is there a way to get them to play or do I have to buy different type discs?
Old Feb 14, 2006 | 01:17 PM
micvog's Avatar
What software are you using and what type of discs are you burning? For example, iTunes can burn Audio CDs (which have worked for me in the TL), MP3 CDs (which I am almost 100% sure would not work) and backup CDs (which also wouldn't work).
If you are using iTunes to burn Audio CDs (you can see that in the Burning tab of Preferences), I would then check to see if they would play in another car or on your home audio system. If they don't play there either, then try lowering your burn speed to something less than maximum or a different manufacturer. I bought a spindle of Maxell CDs and haven't had a problem but there are a number of variables - who made your CD burner among them - that what works for one may not work for another.
Old Feb 14, 2006 | 01:42 PM
Hawhyen51's Avatar
Did you burn them as a CD-Audio? Or just burned the playlist? If you didn't specify CD-Audio, it will burn the playlist as data. One way to find out is to insert the disc into your CD drive of your computer and check the extension. It should have a CDA extension for audio (I think). Anyone else care to chime in?
Old Feb 14, 2006 | 04:09 PM
datmrman's Avatar
Yes, on the computer, music tracks on a regular audio CD have a CDA extension. Try putting your self recorded CD into another CD player. Maybe your home CD/DVD player. If it doesn't work on those, then something is fishy with your burn.
In most CD recording software, make sure you select "CD Audio" (versus Data CD) when creating a new disk. Also, many older model CD players do not like multi-session disks. Selecting "finalize disk" option will force a CD to be single session and more compatible with many players.
Hope that helps!
Old Feb 15, 2006 | 01:52 PM
Superskate's Avatar
5th Gear
Thanks Y'all! Yes, I was trying to record to DATA instead of Audio-CD. Everything works perfectly now!!!!!
Old Feb 15, 2006 | 02:05 PM
Hawhyen51's Avatar
Now you can burn CD's to your heart's content. Enjoy the day, Skate!
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
lbabus
Oct 12, 2015 07:00 AM
hashbrown
Sep 29, 2015 12:13 PM
mars
Sep 28, 2015 11:03 AM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
