Can't pair phone with HFL
I've tried many times to pair either of my phones (Droid 3 and Iphone 4s) with my 2005 TL without any luck. I have gone through and cleared any existing phones in the system and I can go through the pairing process to the point where it's searching for the phone, but I never see the car show up on the phone itself. Any idea what the deal is?
Yep both phones had bluetooth turned on and discovery mode was on as well. I had them searching for an available bluetooth signal and the car would never come up (while I had the car in the pairing process itself).
try entering code 1,2,3,4
that worked for me - ipone5
if you are still stuck, go here and they will help you.
http://www.acura.com/handsfreelink.aspx
My handsfree wasnt showing up when my iPhone 4 was searching for Bluetooth devices, try disconnecting the battery (vehicle battery) for 30+ minutes. It worked fine for me after I did that... once it shows up in your phone press the talk button, say "phone setup", then "pair", then make the 4 number code for the hands free. Once you set that first you will be able to enter it on your phone and it should connect
mlody
Dec 4, 2019 02:11 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
phillyguerrilla
Sep 26, 2015 11:27 AM
