cant get acuralink to connect
Old Jun 20, 2010 | 09:32 PM
Waltah's Avatar
my iphone 3GS is paired with the car just fine, try to setup acura link and the server connection test fails each time. i do easy setup > at&t (formerly att wireless), and then it fails.
"notification: connection was not confirmed, acura server data will not be available.
what gives?
Old Jun 21, 2010 | 11:02 AM
Mjakaz09TL's Avatar
Good luck getting to work... ive tried several times with my unlocked/jailbusted iphone 3g. Done several searches etc and nothing.
if you figure it out let us know. Try calling ACS and c if they can help u?
Old Jun 21, 2010 | 06:02 PM
Waltah's Avatar
damn mine is jailbroken as well. ill be getting the iphone 4, ill try with that on thursday night.
Old Jul 17, 2010 | 01:43 AM
rmfpdx's Avatar
Did it work? I have an iPhone 4 and can't get it to work with Acuralink either (nor would my iPhone 3GS connect). Why doesn't Acura work with Apple to ensure data download compatibility?
Old Jul 17, 2010 | 01:48 AM
2QAYL's Avatar
acuralink? im confused what do u mean by acuralink. my jailbroken iphone 3g hooks up with the car no problem and i can make and answer calls.
Old Jul 17, 2010 | 08:39 AM
Waltah's Avatar
got my iphone 4 a couple weeks ago, still cant get it to connect.
2QAYL, my phone syncs via bluetooth and everything but when trying to connect to acuralink it fails. it is a feature for service appointments and such
Old Jul 18, 2010 | 08:23 AM
acuratech239's Avatar
Acura Cert MASTER TECH
It's not working because the phone doesn't support data connection. See for yourself, by going to http://www.handsfreelink.com. Scroll down to the bottom a bit, on the left, and then enter all your info. Then look at the details, and you'll see under "data connection" that there is an "X". (And data connection is what you need to allow AcuraLink to work).
I have found the a lot/most phones don't support this feature, or at least most of the phones that people own don't support it.
Old Jul 18, 2010 | 08:28 AM
Waltah's Avatar
thanks for the info.
kind of dumb that everything works perfectly except for acuralink.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
jpadilla
3G RLX (2013+)
Sep 27, 2015 07:53 PM
