Can't call thru HFL w/Blackberry Tour 9630
I got the BB about 2 months ago. The HFL could not find the BB, but I finally got the BB to search and find the HFL. It worked great.
About 3 days ago, when I tried to call a saved contact, the HFL said the phone is busy. It also gave the same "phone is busy" when I dialed thru the HFL. The only thing I can do is dial on the BB and transfer it to the HFL.
I decided to delete the bluetooth connection from the BB and reconnect it. Again, I only got it to work with the BB finding the HFL.
Unfortunately, I still can not make a call thru the HFL.
Any ideas?
Any ideas?
The Tour isn't compatible with the Handsfreelink setup in the TL.
http://www.acura.com/handsfreelink.aspx
Joe
Joe
Did you do a software upgrade on your phone as well? If not, check RIM's web site for any firmware/OS update for you phone. Sometimes does out of nowhere issues get resolved with software/firmware updates.
Joe
Joe
Post #1... go easy on a TL noob, but..
My tour was doing the same thing..ie.. couldnt answer an incoming call. I did some experimenting with the bluetooth options once the car and phone are connected... if you go into HFL bluetooth options and turn off the encryption, i found that worked for me..just an idea, but thought i would share.
phillyguerrilla
09-26-2015 11:27 AM
