Can you use 4ohm & 8ohm speakers together
I'm in the process of upgrading my front door speakers as I have infinity kappa on there now...my rears are midrage 4ohm and the speakers I want for the front are 8ohm ...can I use them with my 2channel amp? Rears on one channel and fronts on the other?
Right now I don't have that problem as they all are 4ohm....
The impedance isn't the real issue I see here.
How are you planning to power a pair of of L and R channels off ONE channel and manage front and rear?
If you are planning to do what I think you are, it won't work.
Engineer in Training
Stop !!!!
If your using a passive crossover the coils will only be 1/2 of what you need, so if you have a series c/o you'll cook the tweeter.
the difference between 4/8 ohm coils for 2400hz .512mh & 1.06 for 8 ohm. So in thoery 2400hz will be 1200hz. this is on a 12db 2nd order.
InFaMouSLink
10-30-2015 09:43 AM
polish_pat
09-25-2015 12:24 PM
