Bluetooth/voice command question????someone help me!!!!
Old Mar 26, 2014 | 03:28 PM
72types's Avatar
5th Gear
Unhappy Bluetooth/voice command question????someone help me!!!!
i have a 08 Tl and i when i bought the car a couple of months ago i didn't notice it had a passcode for the voice command/Bluetooth i guess..but what should i do to get that passcode reset ???????dealer???
Old Mar 27, 2014 | 02:49 AM
Will Y.'s Avatar
Registered but harmless
Welcome to AZ. Please decrease your font size-- it takes up too much room on screen.
The HFL/Bluetooth and Navi/Voice-command are two separate functions controlled by different toggle switches.
Are you able to use voice commands for A/C and radio controls using the toggle switches on the back of the steering wheel?
Are you having difficulty linking a phone using the switches on the front of the steering wheel because the HFL asks for a code?
Old Mar 27, 2014 | 03:29 AM
onesiktl's Avatar
First off welcome here! second use the search function
Old Mar 27, 2014 | 07:23 PM
72types's Avatar
5th Gear
The button work..but it just says the system is locked
Old Mar 27, 2014 | 09:06 PM
Will Y.'s Avatar
Which button do you activate that says the system is locked?
If you pull on the button to activate it, that is the Voice Command button for the Navi.
If you push on the button to activate it, that is the HFL/Bluetooth.
Either way, look in the owner's manuals and for a sticker on the glovebox to see if a passcode is written down.
If you do not get the code, try several common 4-digit pins (0-0-0-0, 0-1-2-3, 1-2-3-4) to see if one of those is the code.
Otherwise, I believe you do have to go to a dealership to reset the passcode on the HFL/Bluetooth.
Old Apr 3, 2014 | 10:14 AM
vakero's Avatar
3rd Gear
I have a hfl module for sale 60$
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
gatrhumpy
19
Dec 31, 2015 04:22 PM
DerrickW
Nov 15, 2015 05:52 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
