Bluetooth Range?
Old Jun 30, 2005 | 06:50 PM
Yakuza70's Avatar
Bluetooth Range?
Does anyone know the range of Bluetooth? When I was changing my door lock setting in my car while it was in the garage, I noticed my phone was still connected to my car via bluetooth even though it was upstairs in the house (probably 50 ft and several walls away)! I was under the impression that Bluetooth was only short range.
Old Jun 30, 2005 | 06:56 PM
AMIC's Avatar
Fightin' Texas Aggie
A Google search revealed that the effective range is about 32 ft (10m). I would assume this is the maximum range you could go and actually still use the device. I too can still see the phone icon in the display eventhough the phone is inside my house. A test revealed that it didn't really work when attempting to use it at that range.
Old Jun 30, 2005 | 06:58 PM
ASP's Avatar
ASP
Earl Shod
I've been well past the standard 10 meter range. In fact, I was once in the parking lot at my GF's apartment. My phone was three stories above, inside the apartment, sitting by the couch and I was able to make a crystal clear call w/ my RAZR. Pretty slick.
Old Jun 30, 2005 | 08:35 PM
crazymjb's Avatar
Would battery level play a part, what about different types of phones?
Old Jun 30, 2005 | 08:40 PM
AMIC's Avatar
Was your car parked right underneath the window and was the phone on the couch near a window? That can make a big difference as opposed to having to go through walls.
Old Jun 30, 2005 | 08:55 PM
ASP's Avatar
ASP
Earl Shod
No, we are talking through an exterior wall, past a baby grand piano, an end table and then a couch. All on the third floor. My car was about 20 degrees East of the room, 20 feet from the wall.
Old Jul 1, 2005 | 08:41 AM
AMIC's Avatar
That sounds pretty good then. Mine is also a RAZR and I couldn't get it to work at all when the phone was inside the house and the car was in the garage.
Old Jul 1, 2005 | 11:23 AM
rbf351's Avatar
Registered User
i know when i let my Fiance use the TL i know when shes coming up the block cause my phone beeps and connects it's self
Old Jul 1, 2005 | 11:30 AM
leeherman's Avatar
Supreme Underlord/Abyss
I left my phone on my kitchen counter (20 or so feet away) while I was washing the car. I opened the windows to turn on the stereo, and heard "You have an incoming call".
I love HFL!
Old Jul 1, 2005 | 11:35 AM
MeltdowN's Avatar
Just because the phone says it is connected, does not necessarily mean it is. I noticed that the TL does not explicitly disconnect the connection when you turn off your ignition. Eventually, however, the connection times out.
Moreover, there are two classes of bluetooth, 1 and 2. Class 1 allows connectivity of up to 100m and class 2, up to 10m. All phones (AFAIK) use Class 2 (to save power). Some USB dongles use Class 1. I don't know if the TL uses class 1 or 2. From what I'm hearing, it looks like it's using Class 1.
Old Jul 1, 2005 | 07:01 PM
ASP's Avatar
ASP
Earl Shod
This is by design and it's in the manual.
MetalGearTypeS
Aug 29, 2016 08:28 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
SUPRMN84
Oct 7, 2015 09:46 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
jmaxima03
Sep 27, 2015 10:22 AM
