Bluetooth not working.
Old Mar 11, 2014 | 03:06 PM
pan0phobik's Avatar
Unfortunately, I did not test the bluetooth on my car to see if it's working before I bought it. It's simply not working at all. Zero response from the buttons for it. Is this as simple as a busted fuse possibly? What things should I look for to diagnose the cause?
Thanks.
Old Mar 11, 2014 | 03:08 PM
pan0phobik's Avatar
Forgot to add: It's a 2005 TL.
Old Mar 11, 2014 | 03:09 PM
Butter type-s's Avatar
You can research the forum for the bake option. My bluetooth on my 08 TL-s when out one day, I decide to try the bake method and I tell you what it work. Save me 200 dollars for a new unit. Take the bluetooth unit out and bake it for 8 minutes at 350.
Old Mar 11, 2014 | 03:57 PM
kineticbluewhat's Avatar
Bluetooth fail
Wait what!! Are you seriously recommending baking the Bluetooth in the oven to fix it? How does that fix it?
Old Mar 11, 2014 | 04:25 PM
pan0phobik's Avatar
Yeah... Going to needs more confirmation before I start tossing electronics in the oven.
Old Mar 11, 2014 | 05:13 PM
Bake fixes solder
Pan
Baking it resets the solder paste by liquefying then resetting when it cools which may fix a circuit issue.
Check out this forum https://acurazine.com/forums/showthr...4#post14765734
Old Mar 11, 2014 | 07:19 PM
Yeah I was skeptical at first too but it works. My unit it's up and run for the past two months.
Old Mar 11, 2014 | 07:30 PM
jthiessens's Avatar
I tried this last night and did mine at 385 for 8min and at about the 7min mark I started to hear some of the components off the HFL unit hitting the bottom of my oven and when I took it out solder had oozed out from around some of the chips mounted on the board. I contacted ack today and he said he had a friend that could repair them for $85 plus shipping. I know my unit is ruined but if I was to do it again maybe try 350 and 7min or just contact him and get it repaired. The cheapest I could find a used one was $175 or buy a new one for $220
Old Mar 11, 2014 | 09:09 PM
TBone728's Avatar
HFL motherboard
I just went through it all recently myself. I researched all the threads to include the bake method. I even tried it myself, but maybe I didn't trust it enough when I had it in the oven. It didn't work for me even though there's a few testimonials saying it works. I may try it later just for kicks. I bought a new one for $186 ($176+$10s&h) from acurapartsforless.com. They give you the whole unit--not just the board which makes replacing it a 5-minute job but now all my problems have been resolved.
Old Mar 23, 2014 | 04:24 AM
hotttoddie's Avatar
9th Gear
Hey OP - would you like the '04 repair manual? maybe you can diagnose from that?
all aside- i can see where the bake method would work - Im a EE and if the solder joints went bad over the years this would help.... but - the manual might help diagnose otherwise... j/s...
Old Mar 31, 2014 | 12:17 AM
tta's Avatar
tta
8th Gear
I'd replace the 220uF first. It worked for me.
Old Mar 31, 2014 | 06:15 AM
genokan's Avatar
I've noticed a trend with baking things from our cars. I think people on this forum just like putting car parts in the oven! lol. If it works it works though, as scary as it may be.
Old Aug 16, 2014 | 04:22 PM
cjgfire's Avatar
Tried baking my HFL yesterday. No luck. Bought a new one on Ebay for $200
MetalGearTypeS
Aug 29, 2016 08:28 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
SUPRMN84
Oct 7, 2015 09:46 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
rboller
Sep 23, 2015 02:49 PM
