Bluetooth Module Compatibility
Old Jul 8, 2013 | 12:14 AM
jrowlandesq's Avatar
8th Gear
The bluetooth module (HFL) went out on my '07 TL S Type. I've removed the unit and have been shopping on e-bay for a replacement. Can anyone tell me if all the units are the same with different covers, depending on the model of Acura, or if each model has a different electrical part. My module has a p/n of 83251SEP A200C5. I have found several on ebay but they seem to have slightly different part numbers even though the photos show a plug that appears to be exactly the same. Also will the later model TL unit fit the 07?
thanks
Joe
Old Jul 8, 2013 | 12:59 AM
Will Y.'s Avatar
Registered but harmless
Originally Posted by jrowlandesq
I've removed the unit and have been shopping on e-bay for a replacement. Can anyone tell me if all the units are the same with different covers...
The HFL units have different part numbers due to the attached bezels/shells that coordinate with the different interior colors.
However, the HFL unit for each year is the same, and can be swapped out of a bezel by removing a few screws.
AZ vendors oemacuraparts.com and acuraoemparts.com each have new HFL units for about $180, BTW.
Old Jul 9, 2013 | 10:54 AM
8th Gear
Hi Will,
thanks for the info. I've also been reading the other thread about the HFL failures in which there are some photos of the part. One photo show that there are 2 boards in the unit, motherboard and daughterboard. Mine only has the one board. Is the photo of another unit?
Old Jul 9, 2013 | 10:55 AM
8th Gear
Sorry Will, forgot to tell you that it's in the thread above this one "HFL Fails" by mmclendon. the photos are on the last page of the thread.
Old Jul 9, 2013 | 03:21 PM
Will Y.'s Avatar
Hi Will,
...Is the photo of another unit?
Are you talking about the photos by jsmack27 in posts 534 and 535? If so, that is his Homelink board-- he didn't pull out the HFL.
I don't know how the interior of the HFL is set up, as I never took my HFL apart. The oven-baking procedure didn't come up until a year after I replaced my HFL.
However, there is only one board in earlier photos in that thread of the disassembled HFL which contained capacitors that people were trying to change/reconnect to revive the dead HFL.
Jul 16, 2017 07:33 AM
MetalGearTypeS
Aug 29, 2016 08:28 PM
SUPRMN84
Oct 7, 2015 09:46 PM
adreano17
Sep 29, 2015 08:48 AM
