Bluetooth calls out !!!
Old Apr 24, 2006 | 02:09 PM
royalpia's Avatar
5th Gear
Angry Bluetooth calls out !!!
It seems to happen when I am by Orlando Int.Airport...my phone rings ..I answer ..it hangs up and then calls my last number called on my phone ...this happens every 2 or 3 minutes...the dealer tells me this is due to the airport...has anyone had this problem.....any other time the hands free works well
Old Apr 24, 2006 | 02:13 PM
TailsToo's Avatar
Currently at 50,546 miles
Never happened to me, and I travel to DFW airport all the time.
Old Apr 24, 2006 | 02:33 PM
davenlei's Avatar
I pass by the end of the landing strip at SNA (John Wayne airport) almost every day and I have never had that happen.
Old Apr 24, 2006 | 02:34 PM
drdamian's Avatar
FOR SALE - BM
never happened to me... and what does the airport have to do with it...
Old Apr 24, 2006 | 02:52 PM
datmrman's Avatar
royalpia, see if you can narrow down the problem. Is it your phone or is it HFL? What phone are you using anyway? I would not pair the phone with the HFL and see if it still rings. You could even pair it with another bluetooth headset as well. Experiment with it a little and post your findings.
Old Apr 24, 2006 | 03:06 PM
royalpia's Avatar
5th Gear
Angry type of phone
The HFL is paired to a Samsung A900...if I diasable the bluetooth on the phone then I stop getting calls....my son has the identical phone and if he is with me and he is the last person to have called me... as soon as my phone rings and I attempt to answer it ...within 5 seconds his phone rings and there is no one there.....the dealership has no clue and they are the ones that suggested it was the airport...it's a mystery....I'm going back to the dealer tomorrow again
Old Apr 24, 2006 | 03:07 PM
hostage46's Avatar
Big suprise ... a cluless dealer
His theory is that the local navigation transmitters interfere. ... Are you passing near any obvious large antennas?
Doesn't hold much water, everyone would be reporting this kind of behavior.
Old Apr 24, 2006 | 05:15 PM
datmrman's Avatar
So you're saying that your son's cell phone, which is also a Samsung A900, will ring a few seconds after yours? Is his phone also paired with the HFL in the TL? If his phone is not paired to the HFL, but it rings, I would say its more of a phone problem than an HFL problem.
Have you tried searching the forum for A900 problems?
Old Apr 24, 2006 | 07:52 PM
royalpia's Avatar
5th Gear
Angry Not only my son's phone
My son's phone rings wherever he is if it's the last call made on my phone ...I had made a call to someone else from my phone inside my home....from my car later that day that number was called 5 times every time my phone rang and I answered it...I know it sounds confusing
Old Apr 24, 2006 | 11:21 PM
datmrman's Avatar
So your phone dials the last number everytime you are near the airport with HFL?
Have you tried trading phones for a day with your son? Pair his phone with your HFL and see if his does the same thing.
Old Apr 25, 2006 | 06:07 AM
HiTEC's Avatar
The A900 has documented problems with phantom calls to bluetooth devices.
It was supposed to be corrected in one of the latest firmware upgrade, so you might want to do a FOTA upgrade to your phone.
It's nothing wrong with the car, it's your phone.
Old May 5, 2006 | 04:58 PM
royalpia's Avatar
5th Gear
I downloaded an update on my phone ...have been by the airport twice and no calls .....I guess that fixed the problem ....Thanks
Old May 5, 2006 | 07:57 PM
maluskills's Avatar
Mofo
Try this...
Try this
Since the dealer is convinced its the airport...take a loaner from the dealer (have a service guy join you for the ride if they wanna be 100% sure) and pair your phone to the loaner...and drive the same route and see if it happens....
Hopefully its just your car, so then they will be forced to fix it..
Good luck
MetalGearTypeS
Aug 29, 2016 08:28 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
SUPRMN84
Oct 7, 2015 09:46 PM
thegipper
Sep 28, 2015 01:01 PM
