Blinder M-20 install
Old Jun 2, 2005 | 08:51 AM
jhope's Avatar
9th Gear
Anyone have experiance installing a Blinder M-20 Laser Jammer in a 04 or 05 TL? I'm especially interested in how the sensors are mounted and how to pass the wires through the firewall.
Passing the wires through the firewall is probably going to be the trickiest part for me.
Old Jun 3, 2005 | 07:21 AM
jhope's Avatar
9th Gear
FYI, passing the wires through the firewall with a fishtape was very easy. No need to cut holes, just run it right next to the factory wiring. This would work well for Amps etc...
Old Jun 3, 2005 | 06:12 PM
vp911's Avatar
I assume this is similar to the Escort laser shifter I installed..... if it is, you can see how I did mine at:
https://acurazine.com/forums/showthr...53#post1162453
https://acurazine.com/forums/showpos...3&postcount=38
Old Jun 6, 2005 | 01:30 PM
jhope's Avatar
9th Gear
Already finished. Install was actually not to bad. Where did you get the "add a circuit” for the small blade fuses? I looked at Pepboys and Discount Auto.
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
pistacio
Sep 26, 2015 09:45 AM
TxRzrBk
Sep 17, 2015 01:07 PM
