Baffled by the dual climate control...
Old Jan 3, 2007 | 06:47 PM
rody084's Avatar
has anyone else had the problem that the passenger's side blows the tiniest breeze of air while the driver's side blows out a storm? I set the vent to max and the passenger side gets about 1/5 of the air flow as the driver side... same or different temperature settings...doesnt matter.
I am very confused...anyone encounter this problem before?
Old Jan 3, 2007 | 07:06 PM
THTL's Avatar
have you try it with different mode.
Old Jan 3, 2007 | 07:59 PM
pnoi521's Avatar
Registered TL Owner
Can't wehave different fan speeds for teh passenger and driver?
Or am I confused?
Old Jan 3, 2007 | 08:30 PM
csmeance's Avatar
you can only have 1 speed but you can have diffrent levels of Temp for each side. Check your cabin air filter. TO TEST:
put the controls to 65 auto with the dual feature OFF. then see how much arie blows out on each side.
Old Jan 4, 2007 | 09:09 AM
rody084's Avatar
yea i've tried all the different modes... i'll try the air filter test and get back to everyone
Old Jan 9, 2007 | 05:56 PM
rody084's Avatar
tried having them both at 65 and the blow out evenly... then once i turn up the heat on pass side only (car fully warmed up)... the passenger's side slows down... if i turn up the heat on driver side only then the heat comes out fine...any ideas?
Old Jan 9, 2007 | 06:06 PM
SANS-TLS's Avatar
My TL-S does the same, it must be the fan speed slows down to compensate for the higher temperature, once the temperature is lowered the fan speed get faster to lower to that temp, that is the only explanation i can come up with.,...
Old Jan 9, 2007 | 06:57 PM
csmeance's Avatar
when the heat is turned on, the air comes thru the floor vents mostly and very little thru the top vents.
Old Jan 9, 2007 | 07:38 PM
007TL-S's Avatar
Be kind to us truckers !
double check your setting's on your dash display !
Old Jan 9, 2007 | 08:44 PM
UM Canes's Avatar
I have noticed this as well except mine is completely opposite. W/ the air coming out full blast the driver vent blows lightly and the passenger is very strong...I to am wondering how to fix this, my car has 600 miles on it.
Scott
Old Jan 10, 2007 | 02:38 PM
SANS-TLS's Avatar
Figured it out!! Both passenger and driver side have different modes, so make sure the air is coming out of the same location, mine for instance was driver: top and passenger was coming from the floor, hence no air from the passenger top..check it out thats the problem i bet
Steve
Old Jan 11, 2007 | 09:00 AM
rody084's Avatar
SANS.... i actually set both of them to the same mode so they should've been coming out of the same place... still same problem... good thought though! any other ideas?
Old Jan 11, 2007 | 12:10 PM
Desert_TL's Avatar
TL has sensors to determine the direction of the car and, in conjunction with the time of day, knows if the sun is blasting the passenger or the driver. For example if the car determines that the sun is shining on the passenger, it will probably blow less warm air at the passenger (assuming it's cold outside and you're in heater mode).
Old Jul 17, 2007 | 02:43 PM
AngeloUCF's Avatar
'05 6MT w/Nav A-Spec
Anyone have an issue with the passenger side cc coming out warmer than the drivers side while out of dual cc mode? I put it on max cold auto and pass side is much warmer than the drivers.
Old Jul 17, 2007 | 03:14 PM
gqchicago's Avatar
5mins2disney.com
I had a major problem with my dual climate control...the driver's side would be blowing out hot air while the passenger's was blowing out cold. This was when the car had less than 5000 miles on it. Turns out the mixer baffle or motor was bad and needed to be replaced (under warranty). Might want to get yours checked...
Old Jul 17, 2007 | 05:48 PM
Xx06SickspdTlxX's Avatar
06 TL 6spd. Navi/A-spec
Ive seen with vehicles without climate control that the air temp from the drivers vents is warmer than the passengers, the cause is the system has low refrigerent pressures. But i have never seen or heard of anything that you are describing.
Old Jul 17, 2007 | 06:40 PM
I hate cars's Avatar
Are the vents fully open on both sides?
Old Jul 19, 2007 | 04:36 PM
evoman's Avatar
In my new 2007 TLS, i wish the fan speed setting could go even lower or quieter....seems too loud for a luxury sport car...
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
AcuraKidd
Sep 25, 2015 11:18 PM
