Backup (Reverse) Camera On-Demand
Old Feb 28, 2007 | 09:23 AM
syrophenikan's Avatar
2007 TL Type-S w/Navi
Does anybody have any information as to a way of activating the backup (reverse) camera when in normal "drive" mode? I think it a wonderful feature, but I'd like to use it more than just when backing up the car. I'd like to have it augment the rearview mirror when driving forward.
Old Feb 28, 2007 | 09:32 AM
Forgot to mention...
This is in an '07 TL Type-S
Old Feb 28, 2007 | 11:28 AM
csmeance's Avatar
If I am correct, all you have to do is get another power source to the camer that is sitched. I think this because the drive might just do what dom's device does, switch the screen when the source is detected
Old Feb 28, 2007 | 12:07 PM
6MTUA5's Avatar
No He Can't
That would be kind of nice to make a switch to be able to turn it on, that way when you're not using the navi or a/c controls, you could have another rearview mirror... that would make 4
Old Feb 28, 2007 | 01:03 PM
rodneyc77's Avatar
Retired!!! ON TOP!!!
but isn't it angled slightly??????
I currently have this feature with my '06... thanx to Dom's Unit....
Old Feb 28, 2007 | 04:09 PM
datmrman's Avatar
I remember reading that the factory backup camera connects to the navi DVD-Rom. You'll have to tamper with that harness to get it to work.
Old Mar 1, 2007 | 03:38 PM
Thumbs up Found an answer
I spoke with the lead technician at my local Acura dealership and he provided me with a wiring schematic and a solution that he believes will work.
You will have to remove the main under-dash interior fuse/relay box. If you turn this housing over there will be some wiring harness connectors. Looking at it from the rear, it will be the bottom right harness. The socket is labeled in the book as "P (MICU)". It appears to be a 30-pin connector. If you locate pin-20 there should be a white wire coming off of it.
As a test, place the car in park and simply ground the wire at the pin-20 connection point (while the wire is connected.) This should trip the camera into an active state. If this test works, perform the following to make it switch selectable.
Coming off of the pin-20 connection (no more than a few inches) cut the white wire and place a diode in the line. From the diode, run a wire to a simple switch. One side of the switch will be connected to the new wire coming off of the diode and the other side of the switch will be grounded. The diode prevents the "presence of ground" from being detected by the "A/T Reverse Position Circuit".
The camera should still activate normally when the transmission is placed in reverse, but it will now be able to be activated on demand by your switch.
Old Mar 1, 2007 | 03:55 PM
acura911's Avatar
i did that on my 2005 acura tl.but if you do that when you drive your Reverse lights will stay on when you have the camera on.
Old Mar 1, 2007 | 04:42 PM
special-ed's Avatar
Iro Ridg .308
Good way to keep tailgaters off! I personally like the brake mod button where you just keep pressing a button to make it appear as if you're braking...
Old Mar 1, 2007 | 04:47 PM
Rear lights Activating
RE: Lights coming on when switch is activated...
According to the Acura tech, the diode will prevent that from happening. The "presence of ground" that the camera triggers off of will not feed back into the Reverse Position Circuit. The camera will come on but nothing else in the car will know it has been activated.
Old Mar 30, 2007 | 01:22 PM
psolk's Avatar
Any way that you can share the schematic???
Thanks so much, I was wanting to do this,
-Paul
Old Mar 30, 2007 | 02:36 PM
FuZionBreeZe's Avatar
Can You Feel It?
Isn't this illegal in a way? cause the screen is moving and in a way it's like watching DVD while driving...just wondering that all..
Old Mar 30, 2007 | 03:39 PM
psolk's Avatar
I doubt it. I was just in my buddy's Q7 this weekend and it is in that truck by design. I am guessing it is because it is not viewed as a distraction but a driving aid. A lot of buses and trucks already use cameras instead of mirrors as it is produces better results...
-Paul
Old Apr 20, 2013 | 09:44 AM
michaelm14's Avatar
BUMP...
Anyone done this one a 2010 TL w/ Tech? I've been searching for the wiring diagram and cannot find one either. I think it would be a nice feature as well.
Old Apr 24, 2013 | 04:49 PM
michaelm14's Avatar
I found the complete diagrams on AllData.com, but I can't decipher the proper wire or method. Do the nav/video mods I've seen advertised on here offer the camera on demand as an option?
Old Apr 25, 2013 | 12:57 PM
connork53's Avatar
My friends mom has a G37x and my friend and I used to coast down the highway and put the car into reverse and watch the camera.....try that
Old Apr 26, 2013 | 08:40 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
I'm wondering if the diode will make my left camera input into the nav system stop blinking.
I installed a camera under each side-view mirror, and, using Dom's unit and the blinker, can activate the camera to turn on under my right mirror. It's like Honda's LaneWatch system but I have the only Acura with this. The problem is that when I put on the left signal, the screen blinks. Not sure why.
Old May 4, 2013 | 12:05 AM
simran4h's Avatar
my boys x5 does that too......itd be neat if someone did it
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
