Audio setting reset ?
Old Sep 28, 2005 | 10:33 AM
zafer's Avatar
Angry Audio setting reset ?
Didn't use the car for a month, and all audio settings have reset to default?! Didn't happen with the MDX.....
Old Sep 28, 2005 | 12:49 PM
gt1's Avatar
gt1
` . ' . SUV haterrr
weird... is your battery OK?
Old Sep 28, 2005 | 01:05 PM
zafer's Avatar
Unhappy
Yes, car started right away. My Olds Achieva will shut itself completly off if there is no activity in 21 days, thus loose audio settings and presets like this did. Don't recall reading such a feature in TL's manual. Driver 1 and 2, and XM1 presets were retained fine. Sound, XM2, all FMs gone.
Old Sep 28, 2005 | 01:58 PM
Dumont's Avatar
Team Anthracite Member
Sounds like you may have the dreaded temperature flatine problem, check if you have 3 dashes (---) instead of the temperature and also if your rear defroster is working. If so you have to take it in for repair. There is (at least with mine and a few others here) a problem in the fuse box. I suggest you do a search for temperature flatline in the Problems & Fixes section.
Good luck.
Dumont
05 AM/Quartz AT Navi
Old Sep 29, 2005 | 08:10 AM
ricksvt's Avatar
I had this happen as well a few days after I installed my intake. I check the settings after I put the battery back in the car, all was good. A few days later, I go to start it, and all of my presets are gone and everything. About 1 hour later when I get back in again, everything is back.....wierd
rick
Old Sep 29, 2005 | 09:33 AM
zafer's Avatar
Question
...well whaddya know, the presets are back, hadn't redone them, just had reset the audio levels
still going through tons of vacation mail, saw the recall notice just a while ago, thx.
Old Sep 30, 2005 | 05:09 PM
Adobeman's Avatar
The DVD-A Script Guy
Did you by chance use the other key fob ? The radio, climate, seat and mirrors are all key fob specific. I got in the car with "Driver 2" one day and everything was all f-ed up. Hopped out and got the other key fob and all was right again
Old Oct 1, 2005 | 11:53 PM
ricksvt's Avatar
nope, it was the same fob, the other one wasnt even around the house
rick
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
Pegon95
Sep 15, 2015 01:54 PM
vbgregg
Sep 11, 2015 05:38 PM
braveheart
Sep 7, 2015 08:12 AM
