Audio Button Dead
WDP Type S
Audio Button Dead
hey, I've searched and there were a few pages that i found about the audio button not working or other buttons. But there were never a fix for it. Mines just suddenly stopped working, everything else is working fine. When you press the audio button it does not even make the beep noise. The rest of the button around it is working fine. Any ideas? Reset something?
Make Nice, Not Rice
I had this problem probably about eight times and it went away completely. Try getting out of your car, locking it, unlock it and turn the car back on.
It's something that will go away, if not bring it into ACURA.
WDP Type S
that's a whole lot of times, but yea it just started last night, didn't really have time to look into it. But this morning still same problem. and the now found out that the joystick to scroll around does not work either. thanks for the reply.
the plug probably came loose from behind the monitor...
WDP Type S
Just an update for my problems. I took the car into the dealer today and they I guess they could not find what is wrong with the audio button at all, so they are going to replace my navi unit and they also mentioned that my navi disc is old and they're going to order one also. So hopefully I will be receiving the new navi disc version. I've read a lot of people are having navi problems and blanking out and such, do you really have to replace the whole navi to get it corrected?
* didn't want to create another thread but....
another problem that I ran into was a ticking noise noise recently started to come up, passenger side when accelerating from a dead stop and when the gas is let it, it will tick on the front passenger side. Found out that it was a brake issue and mentioned that it was not the stock brake pads installed and it was installed incorrectly and has about 4mm left of life on the pads. My question, I bought the car CPO at 32k miles and now only have 34k miles, weren't they suppose to change everything on the car if its not OEM? like brake pads?
soupi
14
11-15-2015 11:15 AM
