Audio/amp/sub installation
Old Jan 24, 2009 | 02:23 PM
jvaj's Avatar
7th Gear
Hey guys, i'm pretty new to this site. This may be an old topic but was wondering if anyone knew how to install a sub and an amp combo into the 2008 tl type s, explaination and photos would be awesome if someone could help me out. thanks
Old Jan 24, 2009 | 03:15 PM
greco9885's Avatar
You need to run the power wire from the battery, thru the engine firewall, then run it along the seat and the door under the carpet, under the backseat, the into the trunk. Then buy a Line Out Converter(with a remote wire built in), tap into the factory sub wire, run RCA/remote wires to the amp and your good to go.
Honestly, if you have no idea what I am talking about, pay someone to do it. Its a detailed process(but simple kinda) and you need to know atleast alittle about audio installation.
You will also need to remove the rear Active Noise Cancellation microphone, the front one is not necessary. howto: https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/i-163-amp-sub-installed-08-tl-s-amp-not-getting-signal-when-doors-shut-700991/
Old Jan 24, 2009 | 03:32 PM
jvaj's Avatar
7th Gear
Thanks for the response. I'll give it a go and see how it works! thanks again!
Old Jan 24, 2009 | 03:48 PM
tech14's Avatar
2008 NBP TL
My install thread has some detailed pics, along with a list of good resources on page 2.
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/tech14-complete-audio-installation-643839/
Old Jan 24, 2009 | 05:19 PM
jvaj's Avatar
7th Gear
thanx for the nice pix. that will definately help out for my system.
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
pistacio
Sep 26, 2015 09:45 AM
TxRzrBk
Sep 17, 2015 01:07 PM
